Kappa perfect tweeter locations?
Username: Beek
Post Number: 8
Just purchased a set of infinity kappa perfect components. Ive decided to mount the woofers in the o.e door locations.
But where is the ideal position to mount the tweeters? And what is the best angle to direct them? Ive heard many different opinions:
1)Direct to the ear
2)Directly to the opposite persons ear
3)Up towards the rear view mirror
Or any other ideas?
Bear in mind it is quite a small car. (Opel Corsa)
Very popular over here in England for young modders :-)
Thanks guys....
Username: Jonathan_f
GA USA
Post Number: 960
Close to the woofer in the door (below 5 inches preferably) angled up toward the center of the car works very well for Kappa Perfects. This will still have great detail, and allow the woofer and tweeter to blend vocals together better.
Username: Beek
Post Number: 9
Okay thanks jonathan. I didnt really have enough room in the door so i actually mounted them in the kick panel next to it, seems to sound very crisp and clear there :-)
Im now experiencing a strange kind of sudden sqheel noise as i turn the volume up pretty high.
Is this what you guys call "clipping" ? What causes this?
The amp im using is: 75w rms x 4 @ 4ohms. I know the kappa's are rated 100 rms. Is this what is causing the problem? Because i previously read a thread with u and Matt Lavalee having a big depate about underpowering the kappa perfects?
Username: Ffxdevilarms
Post Number: 43
from what i have read, i think that the kick panel is where infinity recommends they are put.
GA USA
Post Number: 998
Is it a consistent squeal, or one that only happens when a strong tweeter signal is given? It very well could be clipping or distortion, but hard to say by the description.
Username: Beek
Post Number: 11
Its only when the volume is up high and hitting hard notes. I have the gains right down on the amp so im not even getting that much volume at all, just this strange noise.
