A neat little system I've put together.
Username: Levelzero
Post Number: 43
I was playing around with my new camera.
Username: Deadhorse
Post Number: 119
Are those your rear speakers on the stands? Obvious next question...why are they in the front?
Username: Levelzero
Post Number: 46
I was sitting on the couch, in the dark, when I took that picture. The light, of couse, is from the flash. The rear speakers look like the ones you see on the stand, but they're behind the sofa. It's a 7.1 Onkyo system. You can't see the other components very well, but the receiver and disc changer is on the right side of the stand.
Username: Dakangofkrunk16
Boca Raton, Florida
Post Number: 1687
i got the 7.1 onkyo too.. Sh1t is badazz, but i upgraded the Sub wit an 18inch
Username: Shane24
TorontoCanada
Post Number: 226
bullshit system..
Username: Abbaskhan8008
ChiniotPakistan
Post Number: 21
This setup looks powerful�great attention to acoustic detail! When building or upgrading rooms for home theaters or audio setups, precise groundwork matters a lot. I recently found an excellent solution for generator rental in abu dhabi that ensures clean, level surfaces for cable trenches and subfloor installations. A solid foundation really enhances performance!
Need to Register?
Forgot Password?
Enable HTML code in message
