Blaupunkt Car 300 (D) Radio Code
Username: Sebopel
Hi all.
Could somebody help me get the code for my old radio? Would love to get it working again, but just can't find the code though I should have all the original papers.
Model: Blaupunkt Car 300 (D)
Serial Number: GM1300V6675289
no. 90 532 620
Some other number: 7 645 852 320
Thanks a lot in advance!
Sebastian
Username: Regrooster
Post Number: 17348
try code 4444
Username: Sebopel
Didn't work unfortunately, but thanks a lot for your reply
Post Number: 17349
4444 code is correct
Check your Serial Number again GM1300V6675289
Username: Sebopel
It seems to me that this is the correct serial, but I included an image of the radio information just in case. It should be noted that the radio might not work, there is no way to be sure I think. But the number next to CODE goes down each time I try (it's at 7 now), and the display says 'SAFE'.
Thanks again.
Post Number: 17350
Are you using the correct Code Entry Instructions?
Press and hold preset "AS" and switch radio ON
Display shows "SAFE" and then Shows " 10 - - - - "
Press preset " 1 " repeatedly for 1st digit
Press preset " 2 " repeatedly for 2nd digit
Press preset " 3 " repeatedly for 3rd digit
Press preset " 4 " repeatedly for 4th digit
If the correct code number is now shown press and hold preset "AS" until unit beeps
Code 4444 is correct.... if it doesn't work then your may have been recoded in the past to a different number....or it may be faulty
Username: Sebopel
Yeah I did it correctly, also tried again. Oh well. Thanks for your time!
Need to Register?
Forgot Password?
Enable HTML code in message
