Remember your old football card and the Red Dragon card reader, well if you still have them you will need them both for the DTV fix
You may need a older computer just to hook up the original red dragon with your mouse, I had to hook up a old 486 from basement, just because modern computers dont have the same old inputs. There may be a usb conversion that will work
Clean up your old dtv football card, simply swipe it in Red Dragon and enter 500 dollars were it says PPV.
The fix only works on older discontinued SD DTV boxes. NO HD but all wide open...enjoy
Important you may need to do a soft and hard reboot, you may have to reset a number of times until it kicks in, if you get a error message, just ignore unplug from wall wait 30 seconds and plug back in
