Wiring DVC to two different sub box terminals
Aaron T.
Every wiring diagram shows the subs being wired directly to an amp but how do i hook up the 2 DVC subs to the 2 terminals inside my sub box? The subs and amp are both 4 ohm setups
Hydro
Aaron just look at the wiring diagram again and when its shows the part of the diagram with the positive and negative leads running to the amplifier instead of running them straight to the amp run them to the terminals first,then to the amp
