Alright, I ordered 4 Pioneer TS-A1680R Speakers for my 1992 Honda Accord, and I mounted the 2 back speakers and wired them. When I turn on the radio, I notice that Im not hearing much from the right speaker, however the left is playing very nicely. I adjusted the balance so that only my back right speaker was playing, and when I turned the volume all the way up, i could barely hear it. I was positive that i spliced the wires right, but i reversed it anyway, to see if that was the cause, but it was basically the same thing, very, very soft out of the right speaker. Anyone know what could be the problem?
What are you running them off of? If it's the head unit, check the fader, you could have accidentally hooked it to a front channel if you have the fronts faded out.
