Subwoofer box conversion
Username: Dustycarnl
My box is a †Dual 12" 1,600W Max Power Loaded Subwoofer Enclosure Compatible with 2007-2013 Chevrolet Silverado/GMC Sierra Extended Cab Trucks†and I want to try and port it but I don’t think it’s possible is there any way I can?
Username: Joe1234
Post Number: 2072
Ported boxes are much larger than sealed ones so you need a new box most likely.
Need to Register?
Forgot Password?
Enable HTML code in message
