Username: Boopers Lima,
Ohio
United states
Post Number: 27 Registered: Jul-04
Friday, July 30, 2004 - 03:39 GMT I'm sure this is a common problem, but not sure how to fix it, since I got my bigger sub when it hits my lights dim. Is this an easy fix or do I have to look at somewhat major mods to avoid killing my altenator
Username: Southernrebel Louisiana
Post Number: 100 Registered: Mar-04
Friday, July 30, 2004 - 04:00 GMT a new alt. is the only true "fix" most likly...what size is your stock alt. and what amp do you have???
Ohio
United states
Post Number: 28 Registered: Jul-04
Friday, July 30, 2004 - 04:05 GMT have no idea on the stock alt, but the amp is only a little 760 pioneer, wouldn't think that would stress my stock alt though
Ohio
United states
Post Number: 29 Registered: Jul-04
Friday, July 30, 2004 - 04:19 GMT ALTERNATOR 6 3.8 231 1 All 20-1159-31 DR CS144 140 info I got on my alt, guessing 140 is the size or whatnot
Username: Purplehase_bong Bc
Post Number: 117 Registered: Apr-04
Friday, August 06, 2004 - 05:11 GMT well stock alternators put out about between 90-110amps. but it shouldent be a big problem tho.!
