Old pro logic receiver looking to upgrade advice
Username: Vedder_vitamins
Hey, newbie here thanks for your help.
I have an older Sony STR-DE325 that just has pro logic (works very well though). Speakers I have connected are Cambridge Soundworks Ensemble IV with the Center Chanel ll for center. I also have 2 outside speakers (Dual) connected to the B connectors.
I want to upgrade to not only get DTS and Dolby Digital but also a powered subwoofer. (room in 13' w x 20' long.
Without breaking the bank (300-500ish??) what receiver/speaker combo's would you recommend?
I was thinking Sony STR DE 597 with Cerwin Vega AVS 5.1 speaker package. Am I off base?
I have a 5 disc harmon carden cd changer and a Hitachi DVD player, Panasonic27" tv (all newer)
33% Movies
33% TV
33% CD's
thanks so much for your help
BNJ
IMHO
Sony is OK - but I would look at a Panasonic Digital Receiver. Panasonic SA-XR50 ~$260
Spend whats left on the Sub and other upgrades.
Username: Shank
Pittsburgh, PA
You might want to take a look at the Onkyo TXSR502.
You shyould be able to get it for $250-300 range.
As far as a subwoofer, maybe look at the velodyne cht-10, you can get this online from www.jr.com or somewhere else for under $200.
There maybe other equipment that is better for the money, but theis is where i'd look first to get a reciever and sub for under $500.
Username: Kegger
MICHIGAN
Post Number: 1075
mc there is no good way to say it but for your budget.
there isn't a lot of good equipment to choose from.
if you could do it in steps and spend a little more
you'd have a better system that you could keep longer.
it looks like you want a sub, a reciever and 5 new
speakers.
a fairly descent reciever is $300-$500 a descent sub like shank said is about $200.
peronally i'm not a big fan of the little speaker
packages.
I would get a good set of speakers for the front
then get the matching center. for that your talking
in the neighberhood of $600. then use the rest of
the speakers for now that you have allready and
upgrade those later.
now i'm not saying you SHOULD do this i'm just giving
you an alternative way of building your system.
the others have given you soild selections i'm just
giving you another option.
also a cheap good universal dvd-a/sacd player is the pioneer 563a.
$100 but it's been replaced by a cheaper made one
so if you want one better get it fast.
anyways i hope you take my post as an attempt to help
and not put you down for trying to get away inexpensive.
I have no problem trying to be thrifty "trust me"
