Anonymous | I have a nikon coolpix 4200 and dont have the pictureproject installer Cd. What do you suggest I do.I've search for it on nikonmall.com and to no avail. |
New member Username: OcaklilarIstanbulTurkey Post Number: 10 Registered: Oct-05 | Nikon View is better than PictureProject. http://nikonasia-en.custhelp.com/cgi-bin/nikonasia_en.cfg/php/enduser/std_adp.ph p?p_sid=1f5UYaSh&p_lva=&p_faqid=162&p_created=1098298111&p_sp=cF9zcmNoPSZwX2dyaW Rzb3J0PSZwX3Jvd19jbnQ9ODkzJnBfcGFnZT0x&p_li= |
Gold Member Username: Project6Post Number: 4143 Registered: Dec-03 | But what is it that you want to achieve? Do you just want to download the pictures to your PC or do you want to edit them as well? |
Anonymous | Nikon Coolpix 4200 wants to be able to download and edit his material.Does not have pictureproject software that came with camera. |
Gold Member Username: Project6Post Number: 4149 Registered: Dec-03 | Then go with Photo Elements, to edit your pictures. Download nikonview to manage your picture downloads. It is free from the Nikon website. |
