Recently I purchased a NAD C270 amp and it says that will work best if bridged. Can someone please help me to understand how to do it ? The amp has A and B speaker connectors so, do I use A right and B Right ? I am using it for the front speakers.
Bridging will make a two channel amp to a more powerfull one channel mono amp, so you probably dont want that. You will have get an other C270 if you want to use them bridged for the fronts.
Dynarama
Thanks a lot. They sure are not cheap but considerably cheaper than the original price. I will sure consider getting another one.
Ciao
J. Vigne
Excuse me, did he just say his amplifier spoke to him?
is not him is her...and it was the sales guy who told me that, plus the manual says it will provide more power by doing so. Do not know if the quality of the sound will improve as well.
