Radio Code BMW Bavaria Electronic CDII
Username: Igyfancypants
Hi can you please help me. I lost the code to my Bavaria Electronic CDII.
The number is
BP9960P6431729
Username: Iwos
Wales
Post Number: 5724
IgyFancyPants
Hi,
Use this code . . 6546
===> https://paypal.me/CRTM1
c.r.t.m.auto@gmail.com
I just tried it and it went back to the ---- screen... What button should I press after entering the code? And is there a possibility the code has been changed?
Username: Iwos
Wales
Post Number: 5725
IgyFancyPants
Blaupunkt 7 649 960 040
As originally fitted to :
BMW
If the unit is codelocked it will need to be left switched on up for up to two hours to reset before another code entry attempt is possible.
Code Entry as Follows:
Switch radio ON, display shows 'CODE "
Press preset " 1 " repeatedly for 1st digit
Press preset " 2 " repeatedly for 2nd digit
Press preset " 3 " repeatedly for 3rd digit
Press preset " 4 " repeatedly for 4th digit
Press tuning button " > " to enter the code
