New member Username: TzatzikiAthens, Attica Greece Post Number: 1 Registered: Jul-21 | Hello, my battery died on my peugeut and can't find the code for my radio. Info on hardware is 22DC722/65X PHAPFFX6037325 . Thank you in advance! |
Gold Member Username: IwosWales Post Number: 5712 Registered: Jul-14 | Angelos New member Username: Tzatziki ================== Hi, Code is . . 9141 https://paypal.me/CRTM1 c.r.t.m.auto@gmail.com |
New member Username: TzatzikiAthens, Attica Greece Post Number: 2 Registered: Jul-21 | Thank you very much, it worked, but i have to use the password every time i turn it on for some reason. |
Platinum Member Username: RegroosterPost Number: 14304 Registered: Aug-08 | use the password every time i turn it on for some reason. ============================================================ That usually means the permanent battery feed to your radio is not connected Check fuses and connectors |
