I have just purchased a new to me 2002 CLK 320 Radio says "Waiting" it never goes away and the radio never turns on, nor does the CD, or Tape functions. Does anyone have any insights? The antenna is snapped off but the unit is still there. Could this be causing the "Waitng" message?
Hello. The "Waiting" message appears when you try to enter the code incorrectly. Turn on and wait for the radio to ask for a code, but you need to know the correct code. The main thing is not to turn off the radio, otherwise the timer will not work out its time. To get the code, remove the radio from the car and give the serial number.
