Fiberglass?
Does anyone know wheather i should even try building a fiberglass inclosure or just stick to mdf? im trying to put 4 10's in a standard cab with a whole center council down the middle between the 2 seats. everyone has their own opinion and people are like dont try it. but others say its really east. ive also seen it where they build a mdf box and then just lay the fiberglass over so that it looks like the whole thing is fiberglass. any opinions would be helpful.
thanks keith
Macawmagic@aol.com
Brett
If you have never worked with fiberglass, i say dont waste your time and $ on a project like that, when there is a great chance u will screw up.
