To divided or not to devided.
Username: Fetusdeletus
Hi, guys, I'm new around and looking for some help on an install. I have two 10" kicker type r powered by 2 500watt JL audio amps. I bought a sub box to put under the rear sit in my truck. The issue is that the box is not divided. I have called a few shops around and some say its a problem and some say it's not. So well is it? Would you recommend adding one in if possible or shipping the box back and getting one made?
Username: Nekbone316
Well is it sealed or ported to start ? If it were me and it was ported than you could leave it. If it�s sealed I would 100% split them and make sure it�s sealed. But with all that said it depends on what your expectations are out of this set up ?
Need to Register?
Forgot Password?
Enable HTML code in message
