Need advice on amp
Username: Unpopularamigo
New Caney, Texas
How do i choose what amp to hook to my 15" 1500 watt rms subwoofer
Username: Felicitagago
Skar Audio RP-1500.1D could be a good choice for your 1500 watts subwoofer but if you want all details then you can check the best options from here https://99carstereo.com/best-car-amplifiers-review/ one by one with their features like max watts etc. Hopefully, it would assist you in the search of suitable amp according to your subwoofer.
Username: Izfrom205
What do I need too do my amp will not turn on for anything I plugged it up too my brother car and it turns on but it want turn on in my car but my power wire has juice because it sparks when it touches the ground wire
Need to Register?
Forgot Password?
Enable HTML code in message
