Username: Js38756 SHREWSBURY,
Shropshire
United Kingdom
Post Number: 1 Registered: May-19
Thursday, May 23, 2019 - 13:52 GMT Hi. Recently bought a 57 plate boxer with very little documentation and no radio code. Can anyone help? Radio serial is BP535857814849 Many thanks in hope! Cheers, Jeff
Username: Regrooster Post Number: 12640 Registered: Aug-08
Thursday, May 23, 2019 - 17:28 GMT try code 3533
Shropshire
United Kingdom
Post Number: 3 Registered: May-19
Thursday, May 23, 2019 - 19:30 GMT Hi RR. Thanks for that. In the garage for a new cambelt so I'll give that a try hopefully tomorrow.
Username: Mickm147livecouk Post Number: 2 Registered: May-19
Monday, May 27, 2019 - 07:22 GMT can any body help to get radio code on my peugoet expert pu-2294b serial no cl0402x0050189 thanks
Username: Regrooster Post Number: 12646 Registered: Aug-08
Monday, May 27, 2019 - 12:49 GMT m moore New member Username: Mickm147livecouk Post Number: 2 Registered: May-19 Posted on Monday, May 27, 2019 - 07:22 GMT can any body help to get radio code on my peugoet expert pu-2294b serial no cl0402x0050189 thanks =================================== Do you have another label with twin barcodes , the lower one beginning with C7000000xxxxxx ?
Username: Mickm147livecouk Post Number: 3 Registered: May-19
Monday, May 27, 2019 - 15:50 GMT hi no there is not another label.
Username: Regrooster Post Number: 12647 Registered: Aug-08
Monday, May 27, 2019 - 17:19 GMT Sorry...then it's the Main Peugeot dealer or a Radio Decoding service for this code
Shropshire
United Kingdom
Post Number: 5 Registered: May-19
Tuesday, May 28, 2019 - 16:42 GMT Hi RR. Just got the motor back and tried to put the code in but all that is showing on the display is WAIT. I've tried Clr (clear) but no change. Any idea on what I need to do to get the display up so I can try the code you suggested? Many thanks, Jeff
Username: Regrooster Post Number: 12650 Registered: Aug-08
Tuesday, May 28, 2019 - 17:32 GMT Jeff New member Username: Js38756 ==================== Leave it switched on ( undisturbed) for an hour or longer and the display should reset
Shropshire
United Kingdom
Post Number: 6 Registered: May-19
Tuesday, May 28, 2019 - 18:52 GMT Hi RR. Thanks for the advice. I'll give that a try. Cheers, Jeff
Shropshire
United Kingdom
Post Number: 7 Registered: May-19
Tuesday, May 28, 2019 - 21:04 GMT Hi RR. It took 2 hours to clear but finally accepted the code. Many thanks for your help. Cheers, Jeff
