New member Username: GemgemBirmingham, West Midlands United Kingdom Post Number: 1 Registered: Feb-19 | Hi my car battery drained and my radio isnt working, cant find radio code would anyone have an idea for code for 2007 Fiat Multipla without getting the radio out? Thanks in advance |
Bronze Member Username: Le_canardPost Number: 97 Registered: Jun-18 | hi, You must remove the radio and send a photo of the labels stuck on the radio here> https://www.code-autoradio.com/produit/fiat/ |
New member Username: GemgemBirmingham, West Midlands United Kingdom Post Number: 2 Registered: Feb-19 | Finding it difficult to get off have used a Phillips to take the two screws off but it still won't budge. I've looked on YouTube but can't find a vid to follow any ideas thanks |
Bronze Member Username: Le_canardPost Number: 98 Registered: Jun-18 | link > http://www.fitaudio.com/?View=entry&EntryID=48 |
