Unable to enable ARC between Hisense & Yamaha
Username: Videobruce
Buffalo , NY
Post Number: 111
I have a Hisense TV (65U8G) and a Yamaha AV Receiver (RX-V675) and I'm unable to enable the ARC the function. In the TV's menu, the choice is grayed out.
I have the HDMI cable connected between the sole ARC port (HDMI 3) on the TV and the sole HDMI out port on the Receiver. I have the "HDMI Control"function enabled in the receivers menu.
At present, I have been using an optical cable between the former TV (no ARC) using AV4 which is the default. I understood the older ARC does not need any 'enhanced' cable to work. Is that correct? Yamaha's audio settings have always been confusing to me especially when it's a separate (non HDMI).
Any ideas or questions if my explanation isn't clear enough??
Buffalo , NY
Post Number: 112
I should add, this is for the TV's tuner and Internet applications (Netflix & Prime Video). It would be nice to get rid of the optical cable. I'm assuming the HDMI path would be an improvement over the optical, or is this ARC overrated and buggy??
I know they both are PCM and I believe both are 5.1. Correct me if I'm wrong.
Need to Register?
Forgot Password?
Enable HTML code in message
