New member Username: Jose_brandaoPost Number: 2 Registered: Oct-18 | Boas preciso do código do rádio gm0400x2508097 pois fiquei sem bateria e não consigo ligar o rádio. |
Platinum Member Username: RegroosterPost Number: 12425 Registered: Aug-08 | Opel dealer or Radio Decoding Service for this code |
New member Username: Jose_brandaoPost Number: 3 Registered: Oct-18 | Ok Red Rooster obrigado j� vi que n�o e f�cil conseguir o codigo |
Bronze Member Username: Le_canardPost Number: 43 Registered: Jun-18 | Try here => http://www.code-autoradio.com/ Mention this Forum to see if they can help |
