Last week i downloaded wimanp om my desktop to watch a cricket match, that was site's demand, so after that as i didnt need it, I deleted it. Now wen i m trying to play a downloaded video clips, of my camera, I couldnot and Im getting a message "Winamp has encountered a problem and needs to close. We are sorry for inconvenience." Can someone help me with this.
did you delete or uninstall winamp? If you just deleted it you have left part of the program info in the registry of your pc. You will need to go to control panel, add and remove programs. Find winamp and remove it that way. Dantetn's method will work to choose another program to use as well as make it your default viewer. I am just letting you know how to remove a program properly. Sorry if that is the way you done it by add and remove. Just trying to help.
