Renault Scenic Meganne Radio code
Username: Adruffs
Number under the barcode is
7700434426TL832
Can you help to decode please?
Thanks
Username: Eve1990
Post Number: 958
Rufus
Username: Adruffs
code is 2305
If you would like to support the activity of the page,
you can leave a quick tip via paypal.
mail Eve28021990@yahoo.com
Many thanks
Username: Stoviejoe
I have the same problem after flat battery. The number under the barcode is:-
7700434424TX493
Can you help to help find the code please?
Thanks
Username: Eve1990
Post Number: 959
Jim
Username: Stoviejoe
code is 2598
Many thanks
Username: Stoviejoe
Thank you!
Username: Adruffs
the code 2305 did not work. It just displayed OTHERS.Thanks
Username: Dekster
POLAND
Post Number: 2833
Rufus
Code Entry as Follows:
Switch Radio On - Display Shows
" CODE " Then " 0000 "
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press and hold preset " 6 " To Enter
" 0000 " with the 1st digit flashing
Rotate " Thumbwheel " For Correct Digit
Press " ¬ " On The Stalk Control To Enter
Press And Hold " ¬ " Until A Beep Is Heard
http://koddoradia.pl/
contact me: s.uanakonda@gmail.com
