New member Username: CraworthLady verney close, High wycombe United Kingdom Post Number: 1 Registered: Aug-17 | Hi I have just bought a peugeot 2001 & need a radio code. previous owner didnt have it Other than getting one from e-bay for £25 I cant get one. Could you help please? Serial No CL041010245770 Model No PU-2325A(B) Many Thanks |
Gold Member Username: DeksterPOLAND Post Number: 2806 Registered: Sep-12 | Chrissy Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. http://koddoradia.pl/ contact me: s.uanakonda@gmail.com |
