Code for radio
Username: Craworth
Lady verney close, High wycombe United Kingdom
Hi I have just bought a peugeot 2001 & need a radio code. previous owner didnt have it Other than getting one from e-bay for £25 I cant get one. Could you help please?
Serial No CL041010245770 Model No PU-2325A(B)
Many Thanks
Username: Dekster
POLAND
Post Number: 2806
Chrissy
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
http://koddoradia.pl/
contact me: s.uanakonda@gmail.com
