Code for a Peugeot 307 Clarion radio
Username: Adile
Hi all,
I lost my code for my car radio. It is an original Peugeot 307 Clarion radio.
S/N: CL05431293879G
Model: PU-2471A
VIN: UF33CRHYB83356433
Could someone help to provide me the code?
thank you.
Adile
Username: Camel131
Post Number: 106
adile
Username: Adile
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
maelysclavel@gmail.com
Username: Adile
Thank you for your input Camel.
I have a number on the metal casing H3111306A.
Is this the number you mean?
Adile
Username: Camel131
Post Number: 111
adile
Username: Adile
Sorry....your code will only be available from someone with access to the Main Dealer database or the unit will have to be taken into a Radio Decoding Service
It is unlikely to be available for free from anywhere on the Internet
