Infiniti G37 without navi, backup camera and bluetooth audio
Username: M4gnum
Lindenhurst, NEW YORK
Hello.
I just bought a 2009 Infiniti G37x. It does not have navi, sensors or backup camera. I would want to have the rear view camera and navigation or a phone screen mirroring so I could use the phone navi. It would be also great if I could play music using bluetooth. What is the easiest way to make it work without spending much money?
I searched through lots of forums and I think I found a solution but I have no idea if its going to work and how to make it work. I would be grateful if someone could have a look and help me with this.
These are the thinks I want to buy:
www.navtool.com/infiniti-gcoupe-sedan-2007-2009-without-nav-hdmi-interface.aspx
https://amazon.com/TOPTIERPRO-TTP-C12B-Installation-170-Viewing-Waterproof/dp/B018800TR2
https://amazon.com/Wireless-Transmitter-Receiver-Vehicle-Backup/dp/B008Z9E4DW
https://amazon.com/Actiontec-ScreenBeam-Wireless-Receiver-SBWD60A01/dp/B00O14JG2Y
https://amazon.com/Mpow-Bluetooth-Receiver-Streambot-Hands-free/dp/B008AGQMQC
I was thinking about connecting the navtool module to the screen unit, than plugging in the wireless screening device so no wires are going to be visible. I want to buy that camera and drill a hole in the chrome spoiler little off the center and put it inside, than I want to connect the wireless transmitter with the camera and the receiver with the navtool module. I think I have an AUX input so I could plug in the bluetooth receiver to play music. It would save me lots of time and make it very easy to setup. I could have the reverse activated camera, wireless connected Waze navigation and bluetooth streaming music. Would my plan work?
Need to Register?
Forgot Password?
Enable HTML code in message
