Looking to replace factory speakers
Username: Chevyboi
Baker, LA USA
Post Number: 73
I have a 09 Silverado crew cab and I want to replace the door speakers, watch are 6.5's. I wasn't too keep the price under $160 if I can. I want to use component speakers since I hear they are the better choice. I have have any power for then yet
Username: Joe1234
Post Number: 1790
check these out:
http://www.sonicelectronix.com/item_9109_Polk-Audio-db6501.html
http://www.sonicelectronix.com/item_34364_Alpine-SPR-60C.html
Username: Ceejay112
Post Number: 9
I have benz s430 2000model.....just brought from the state, I don't know my the speakers are not working and the volume can't be increase or decrease. Radio is working but no sound and the speakers r very okay...Pls Wat can I do?
Username: Niloy
California, United States Bangladesh
Post Number: 9
Components speaker are great and they sound well. But Coaxial speakers are not bad. If you buy a great coaxial speaker that will provide you quality sound. Before buy any of type of them you should know well about them.
Check out this detailed article about Components VS coaxial speakers:
http://carmusiclab.com/component-vs-coaxial-speakers/
https://www.youtube.com/watch?v=ThAIOuiOLnA
Need to Register?
Forgot Password?
Enable HTML code in message
