Ford fiesta finesse radio code lost.
Username: Darrengregory
Hi all. My daughter has just bought an old car which has a factory fitted radio/cd player. Unfortunately it's code is locked. She says the serial number is 097902. Is this enough information. Can any of you wonderful people help. Thank-you millions in advance.
Darren.
Just an update. her radio make is 4500 rds eon. Thank you again.
Username: Tech13
Post Number: 566
Darren
Hi,
M097902 code is 3604
Thank you billions we will try it now.
Worked perfectly. Thank you so much.
