New member Username: OrbergaKöpingSweden Post Number: 1 Registered: Jun-16 | could i get help retrieving a radio code for a clarion R-D-S / EON PU-2294A *C70000002624 Thank you! |
Silver Member Username: Eve1990Post Number: 355 Registered: Feb-16 | Gabriella New member Username: Orberga code is 3252 If you would like to support the activity of the page, you can leave a quick tip via paypal. https://www.paypal.me/eve1990 Many thanks. |
New member Username: Lukep95Post Number: 2 Registered: Jun-16 | Hi there code needed for PU-2294A SERIAL CODE: CL0401X0013902 THANKS |
Gold Member Username: IwosAZERTY Post Number: 2295 Registered: Jul-14 | Luke Price New member Username: Lukep95 ================================== Hello, Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. |
New member Username: AshgunnellPost Number: 1 Registered: Jul-16 | Hi there code needed for PU-2294A SERIAL CODE: C7000005622 THANKS |
Gold Member Username: IwosAZERTY Post Number: 2354 Registered: Jul-14 | Ashgunnell New member Username: Ashgunnell ================ Hello, Your code is . . . . 6256 Is if you would like to support the activity of the page, you can leave a quick tip via paypal. Paypal email address : c.r.t.m.auto@gmail.com Email Contact : c.r.t.m.auto@gmail.com Many Thanks |
