New member Username: DskackaPost Number: 1 Registered: Apr-16 | Hi,can anybody help me with radio code for my Nissan Note 2008 MMR#2CD-G BP738387802440, 7647383318 Thanks |
Gold Member Username: DeksterPOLAND Post Number: 2547 Registered: Sep-12 | DON CODE 0549 contact me: http://koddoradia.pl/ |
New member Username: Cm_ngobeniPost Number: 3 Registered: May-16 | Hi , can someone pleas help me with my car stereo code, recently disconnected my car battery , once it was connected my stereo is asking for code , but i don't have one , info as follows: Renault Grand scenic 2006 model RADIO SERIAL NO:RNRD0350296532 |
Gold Member Username: IwosAZERTY Post Number: 2208 Registered: Jul-14 | collen New member Username: Cm_ngobeni ================ FD0805160296532 8200300858TN972 ================ Hello, Your code is . . . . 2077 LES CODES SONT GRATUITS THE CODES ARE FREE LOS CODIGOS SON GRATIS But nothing prevents a member to make a donation if he is happy with our services Is if you would like to support the activity of the page, you can leave a quick tip via paypal. Paypal email address : c.r.t.m.auto@gmail.com Email Contact : c.r.t.m.auto@gmail.com Many Thanks |
New member Username: DskackaPost Number: 2 Registered: Apr-16 | Dexter you are legend!!!! Thanks Don |
New member Username: EdleejayPost Number: 1 Registered: May-16 | Hi, I changed the battery on my Mercedes Benz and the radio needs a code. I need help with my 1999 Mercedes Benz ML430 radio. The VIn is : 4JGAB72E4XA076336 |
Gold Member Username: Titanum123Post Number: 1446 Registered: Oct-13 | Eddie New member Username: Edleejay CODE 53223 contact me: dekcode7@gmail.com free codes |
Gold Member Username: IwosAZERTY Post Number: 2228 Registered: Jul-14 | Eddie New member Username: Edleejay ================================ R.A.S |
New member Username: Kowie42Post Number: 1 Registered: May-16 | HI,I have the same problem as the others,the vehicle is a Renault clio,the numbers on the side of the radio are as follows RNRDAN60056476,BS0106280056476,8200607915T, SECURITY X337,I have acquired what was supposed to be the correct code, but when it was entered it went into error mode, this is totally doing my head in,can anyone please HELP, Cheers..... |
Gold Member Username: Titanum123Post Number: 1449 Registered: Oct-13 | paul New member Username: Kowie42 CODE 2609 contact me: dekcode7@gmail.com free codes |
New member Username: Kowie42Post Number: 2 Registered: May-16 | Hi again, thanks for the reply, this is the same as the code I've acquired, which does not work, any other ideas? cheers.... |
Gold Member Username: Titanum123Post Number: 1450 Registered: Oct-13 | paul New member Username: Kowie42 Code Entry as Follows: Switch Radio On - Display Shows " CODE " Then " 0000 " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press and hold preset " 6 " To Enter Code Entry as Follows: Switch Radio On - Display Shows " 0000 " with the 1st digit flashing Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit Press " ¬ " On The Stalk Control To Enter Rotate " Thumbwheel " For Correct Digit If the correct code number is now shown Press And Hold " ¬ " Until A Beep Is Heard contact me: dekcode7@gmail.com |
New member Username: Kowie42Post Number: 3 Registered: May-16 | HI, thanks for your reply, I've tried all of the above, but to no avail,it just keeps putting error message on display,is there another way round this? Or some master code that would over ride the error message,i am living in anticipation ). |
New member Username: Daniel27kPost Number: 2 Registered: Mar-16 | Hi can anyone help need a code for car radio Ford vnr9000 Kaem015918 |
Gold Member Username: IwosAZERTY Post Number: 2233 Registered: Jul-14 | Dan New member Username: Daniel27k ================ Hello, Your code is . . . . 1293 LES CODES SONT GRATUITS THE CODES ARE FREE LOS CODIGOS SON GRATIS But nothing prevents a member to make a donation if he is happy with our services Is if you would like to support the activity of the page, you can leave a quick tip via paypal. Paypal email address : c.r.t.m.auto@gmail.com Email Contact : c.r.t.m.auto@gmail.com Many Thanks |
