Xd card formatting, photo retrieval
Username: Shellegman
can i retrieve photos before I format? or after.
if so can I do this for free
Username: Jesgrid
Hi,
You can easily retrieve all your photos from your XD card before formatting depending on the operating system you are using. If you are using Mac OS then, you can do it by making use of good memory card recovery software for mac. I am familiar with Remo Recover software. The demo version of this software is available free. I think you must give it a try.
Username: Parsonssmith
No matter if you format the XD card, this Recoverit can help to recover lost photos from the XD card. But you'd better retrieve photos before formatting the XD card, after formatting some photos can not be recovered.
https://youtu.be/vxg5MkA5wOo
Need to Register?
Forgot Password?
Enable HTML code in message
