Ive just bought a 07 primastar se. It didn't come with a radio code. The radio works fine, as I've not had a reason to interrupt the power supply.. My question is, is the code retrievable through the display of a working unit?
New member Username: Johnny349 =================================== Removing the radio without the disconnect and gives the references listed on labels and engraved on the metal casing.
