Archive through August 17, 2014
Username: Sandstorm3565
Had major work done and now my radio is dead. I couldn't find the code in any of the owners manuals.
Ford Fusion 4500 rds eon serial number m125070
Cheers!
Username: Opelop
Post Number: 2340
CODE 6231
contakt me http://forum.kody-radio.pl
Username: Ahmedol
Hello, I just bought a ford fusion 2005 and it has 4500 rds eon but it is requesting for code, I don't have the Manuel of the car, where can I find the serial number. Thank you
Username: Opelop
Post Number: 2358
press 6nd 2 for few seconds
Username: Ahmedol
Pls do u mean I should press 6 and 2 on the radio?
Username: Banker
Hello, I need code for my radio 4500 rds eon, ser-Nr.: M054874
Username: Titanum123
Post Number: 332
Banker
Username: Banker
try code 0769
Username: Ahmedol
Hello, the serial no for me ford Rds radio is M121955. Pls can you assist with the code. Thank you
Username: Opelop
Post Number: 2370
Daniel Apeakhume
Username: Ahmedol
CODE 3305
Username: Jaybunn
Hi, I have recently brought a ford fiesta and I need a code to unlock it, ford radio 4500 my serial number is m494698. Thank you
Username: Dekster
POLAND
Post Number: 1476
jaybunn
Username: Jaybunn
CODE 9335
contact me: http://koddoradia.pl/
Username: Jaybunn
Thank u mate very much
Username: Curli
Hi i had a new clutch fitted in my fusion. Radio 4500 rds e.o.n m010578. Please have u got the code as havent had radio for 6 months
Username: Opelop
Post Number: 2390
curli
Username: Curli
CODE 8564
Username: Curli
Hi i dont have a 8 on my radio as a preset button. Ive tried to put in the rest of the code but it wouldnt work and i dont know how many attempts i have left. Pleaseeeee help.if its the correct code how to i enter it xxxxx
Username: Opelop
Post Number: 2409
Press preset [ 1 ] repeatedly for the first digit
Press preset [ 2 ] repeatedly for the second digit
Press preset [ 3 ] repeatedly for the third digit
Press preset [ 4 ] repeatedly for the third digit
To save the code press the [ 5 ] key to accept.
Username: Curli
Username: Curli
Sorry didnt see post above x
Username: Curli
Omg thank you sooooo much. U have made me a very happy lady. Yey! Thank u for explaining too xxxx
Username: Shinedawn
I am Shine Dawn, my Ford Fusion had been to the garage for a change in the battery,thereafter the Radio just would not work. Could you pls help me! Details: Ford Fusion -2006, Make: 4500 RDS E O N , Sr. no:M170935
Thanks a ton
Username: Shinedawn
I am Shine Dawn, my Ford Fusion had been to the garage for a change to a battery,thereafter the Radio just would not work. Could you pls help me! Details: Ford Fusion -2006, Make: 4500 RDS E O N , Sr. no:M170935
Thanks a ton
Username: Opelop
Post Number: 2414
ShineDawn
Username: Shinedawn
CODE 0978
Username: Xy1802
I cant find my code for my 4500 eos radio. Can anyone help me? serial number: M484691.
Post Number: 349
xy1802
Username: Xy1802
try code 5819
Username: Ovyx
hello ,please help me find my code
part number:2s61-18c815-ag
serial number M 100552
Post Number: 351
ovyx
Username: Ovyx
try code 4076
Username: Ovyx
qwerty
the code doesn't work mate
Post Number: 352
ovyx
Username: Ovyx
try code 9199
Username: Regrooster
Post Number: 11677
serial number M 100552 code is 9199
Username: Ovyx
thank you very much qwerty and reg rooster.
Username: Ambrus78
Hello,
I have Ford 4500 RDS EON radio, the serial number is M266250.
The radio went wrong, I found the code â€" 0464. It worked but unfortunately the battery was exhausted, I had to change it. Now the radio ask code2. Can You help me?
Thanks a lot.
Post Number: 356
Teréz Ambrus
Username: Ambrus78
try code 0464
Username: Ambrus78
I have already tried the code 0464 but didn't work and asked "CODE2".
I do not know what it means.
Username: Micksy
4500 RDS EON SERIAL NUMBER M015060
Username: Opelop
Post Number: 2440
micksy
Username: Mick
CODE 2458
Username: Dekster
POLAND
Post Number: 1516
micksy
Username: Micksy
CODE 2458
Username: Micksy
THANK YOU VERY MUCH,WORKED A TREAT,GREAT SERVICE.
Username: Mihaela26
Hi could you please help me with the code radio. Ford Fusion 2 plate 55 and 4500 RDS E-O-N
MO488899.
Thank you!
Post Number: 395
mihaela26
Username: Mihaela26
The correct radio SERIAL NUMBER MO48889? is required for a code
Username: Elizabethfarmer
Hello I am looking for a radio code for A ford fiesta 03 finesse. Serial number M262704. If anyone could help it would be greatly appreciated..
Username: Dekster
POLAND
Post Number: 1593
Elizabethfarmer14
CODE 9084
Username: Ciprianciobanu
Could enyone help me with code for RDS 4500 Ford Fiesta 2004, with serial M558118?
This is the 11th time I will try the code..
The code from the producer book is 4918, but it didnt work.
After entering the code, should press 5, no?
Doesnt work...
Please help...
Thanks
Username: Dekster
POLAND
Post Number: 1597
ciprian
Username: Puffer1972
Good day to everyone!
After a battery failure my 4500 rds eon is locked
I would appreciate if you could tell me the code for serial: M034417
Thank you in advance!
Username: Decode_radio
Post Number: 164
puffer1972
CODE 6602
Username: Gregos
Hello!
Can anyone please assist me a code for keycode for Ford Fiesta 4500CD RDS. Serial nr: M339934 . Is there any code generator, or database where i could check? Any help would be appreciated!
Best regards guys!
Post Number: 463
GRegos
Username: Gregos
try code 1720
Username: Gregos
Thanks, I'll give it a try, and get back with the result.
Username: Gregos
Thank you for the code. It works. That was a huge help!
Thks, dekster...
Could anyone give me the code for
M558118?
Thank you v much!
Username: Dekster
POLAND
Post Number: 1611
ciprian
Code 4918 is correct
The radio SERIAL NUMBER is required for a code
It usually begins with M or V followed by SIX digits ...such as M854331 or V555323
Sometimes pressing buttons 6 & 1 together or 6 & 2 will display this number
Otherwise remove the radio from the dashboard and post the SERIAL NUMBER found on a label on the casing
Thanks, Dekster.
The code didnt work for several times. So, I stopped at the 11th try.
Is it posible that code has been changed somehow?
The serial appeares when I prees 6 an 2 and is M558118.
Is it possible to be another code than 4918?
Post Number: 180
ciprian
maybe your radio was recoded
sorry we can't help
Decoding Service only for this code
Username: Dekster
POLAND
Post Number: 1618
ciprian
YES
Sorry we can't help
Username: Opelop
Post Number: 2457
ciprian
NO i think someone recoded radio
Sorry we can't help
contakt me http://sh.st/OoAC
Post Number: 465
iprian
Code Entry as Follows:
Switch Radio On - Display Shows
CODE with " - - - - " flashing
Press preset " 1 " repeatedly for 1st Digit
Press preset " 2 " repeatedly for 2nd Digit
Press preset " 3 " repeatedly for 3rd Digit
Press preset " 4 " repeatedly for 4th Digit
If the correct code number is now shown
Press preset " 5 " to Enter
Thanks, everybody!
The code worked. Maybe I changed one number the last times.
Have a nice week.
Username: Chilledsoap
Hi there
I'm looking for the code to my radio if anyone can help.
It's for a fiesta and it's an 4500 RDS E-ON and the serial number is M009381.
Any help greatly appreciated
Post Number: 473
Sophie
try code 5386
Username: Fordhelp95
Heloo
I am looking for my code, which i have lost
pls. help me soon
my serial number is: MO74458
i have a RDS Eos 4500 radio
many thanks from austria
Username: Dekster
POLAND
Post Number: 1630
FordHelp95
CODE 1642
many thanks ! it worked :D
Username: Technocarb
Hi All,
I need to get the code for my 6000cd focus stereo.
V060274
Can anyone help please?
Many thanks
Andy
Username: Dekster
POLAND
Post Number: 1658
Andy Tech
Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as they are not calculated using software but require access to the Ford factory database( via a Ford Dealer)...which is not commercially available as software.
Otherwise try your Ford Dealer or a Radio Decoding Service
Username: Bazza_boy
Can anyone help I had a new batterey fitted for my fiesta and now the radio needs a code its a 4500 rds e.o.n serial number is m002224 thankyou
Post Number: 514
Barry Gilbert
Username: Bazza_boy
Duplicate post....Already answered
http://www.forum-auto.com/pole-technique/equipement-automobile/sujet395936-5460. htm#t14836864
Username: Marcel88
Hi there, i am in urgent need of help
my serial number for my Ford 4500 rds eon is, \
m120814
many thanks!
Post Number: 531
marcel
Username: Marcel88
try code 0107
Username: Aitormenta_90
Hi! I need to get the code for my fiesta 4500 rds eon radio. The serial number is m050813
Many thanks from Spainn!!
Post Number: 249
aitor
CODE 6465
Hi! i've tried the code but it doesn't work. can anyone help me please?. I've followed the steps but the radio continues asking the code again and again.
i have tested it at home, with a 12v conection, so it is possible that it needs some others conections. i have tried to introduce another different code, and the behaviour is different, it inmediatly asks me for code 2. so i will try to connect it with the correct adaptator, it seems it is going to run.
Username: Flynnys
Hi. Need a code for 4500 rds eon serial number M611896. Can you help...
Username: Flynnys
Help serial number m611896 need a code please.
Post Number: 538
flynny
Username: Flynnys
try code 2070
Username: Donkeydick
hi can you please help i need a code for Ford 4500 rds e.o.n serial number m472809 as we are on the 11th try and the code in the book does not work
Post Number: 602
donkey
try code 8611
Hi many thanks, this worked perfectly, yeah music again !!!
Username: Perana
Hi . I have a 2002 exploder(explorer) that has just had most of the wiring replaced ....now it's asking for a radio code
mod# 6006
ser# M002887
Post Number: 294
Phil
Username: Perana
CODE 4284
Username: Frankheavy
Hi. Need a code for 4500 rds eon (ford fiesta) serial number M017084.
Thanks
Username: Dekster
POLAND
Post Number: 1778
Santiago
CODE 2736
Username: Knightryder
Got a ford 4500 rds radio/cd and need code. Serial number is M271925 please
Post Number: 623
Col
try code 8805
Username: Marico0l
hi, rdse-o-n LOCKED13 and it's driving me crazy.. SERIAL NUMBER: m223489
KEY CODE: 8377
but whatever i do i can't write it in.. the thing with typing number "1" until the 1st number appears on the screen is not working.some help pls ?
Username: Dekster
POLAND
Post Number: 1784
marico0l
Username: Marico0l
sorry we can't help
Main Dealer or a Decoding Service only for this code
Thanks qwerty it worked,driving is less stressful now.
Post Number: 11733
#Marico0l
LOCKED13 means 13 or more wrong codes have been entered previously and now your radio is fully locked.
There are no free answers on the Internet on how to unlock it.
Can only be unlocked by a Radio Decoding Service using special equipment .
Username: Ann_shiju
Please find key code for my 4500 rds radio.
serial no: M158907
Thank you
Post Number: 644
Ann Shiju
Username: Ann_shiju
Username: Cz1985
Hi, I had work done on my ford fiesta. Need a radio code for 4500 rds radio serial number M482802. Thanks
Username: Dekster
POLAND
Post Number: 1825
cz1985
CODE 0443
Username: Cz1985
The code did not work
Username: Dekster
POLAND
Post Number: 1826
cz1985
is the correct code for the Serial Number M482802
" CODE " Then " 0000 "
Press and hold preset "5 or 6 " To Enter
Username: Cz1985
So sorry. Its M482804
Username: Dekster
POLAND
Post Number: 1827
cz1985
CODE 6103
Username: Cz1985
It worked!!! Thank you so much!!!
Username: Bojan969
Hello, I need code for my radio 4500 rds eon, ser-Nr. M015636
Post Number: 662
Bojan
Username: Bojan969
try code 3887
Username: Bojan969
Thanks qwerty, it worked perfectly
