New member Username: ShaneomacPost Number: 1 Registered: Sep-15 | Hi. Hopfully someone can help me. I've added the image thanks in advance.![]() |
Silver Member Username: Decode_radioPost Number: 920 Registered: Jan-14 | Shane New member Username: Shaneomac Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contakt me http://forum.kody-radio.pl |
