Clarion radio code please
Username: Spawn_sco
clarion radio code request
PS-2599D
sn-0052862
cl062540052862
from suzuki vitara 2004
Username: Tech13
dave
Username: Spawn_sco
we can't decode it from serial number
Username: Spawn_sco
Hi - what other info can i give you?
thanks
Username: Opelop
Post Number: 2658
dave
Username: Spawn_sco
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your
radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop
to read/recode the memory chip (EEPROM) inside your radio.
** Paypal account ** ..
c.r.t.m.auto@gmail.com
Username: Spawn_sco
hi, thanks for your reply.
I'll take another look
