Radio code process
Username: Missgeronimo
Trying to put code in a Blaupunkt 520 but it won't beep when pressing AS button, any suggestions?
Username: Opelop
Post Number: 2656
Security Release Procedure
Radio PIN Code:
1. Switch on ignition.
2. Switch on the radio, if turned off.
3. The display shows 'CODE'.
4. Press and hold AS button 8, until a
beep is heard and release the AS-button.
The display shows '10 _ _ _ _', which
indicates that you have ten attempts left
at entering the correct PIN code.
5. Enter the PIN code (see Security Card)
with preset buttons 1, 2, 3 and 4.
Example:
If the PIN code belonging to the radio is
3650.
Display:
Press preset button 1 4 times 10 3 _ _ _
Press preset button 2 7 times 10 3 6 _ _
Press preset button 3 6 times 10 3 6 5 _
Press preset button 4 1 time 10 3 6 5 0
6. Press AS button 8 until a beep is heard
and the radio starts operating.
If a wrong PIN code has been entered
the display will show '9 SAFE'. After the
waiting time '9 _ _ _ _' will be shown on
the display indicating that there are nine
attempts left. The correct code should
now be entered.
** Paypal account ** ..
c.r.t.m.auto@gmail.com
Thanks Opelop is there a delay or something because I can't get it to beep to get the code dashes up.
All working now thanks for your help, it's very much appreciated.
Cheers
