PEUGEOT 206 RADIO CODE
Username: Robbo1962
hi my daughter needs a radio code if you could help please
model PU 2294A©
SERSL NUM CL040110678073
thanks robbo
Username: Opelop
Post Number: 2589
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your
radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop
to read/recode the memory chip (EEPROM) inside your radio.
** Paypal account ** ..
c.r.t.m.auto@gmail.com
