New member Username: MissygrrlPost Number: 1 Registered: Aug-15 | Please help. I just bought a 2012 Holden barina spark but the owner had replaced the battery and doesn't know the code. I took ownership papers to Holden dealership but the service department was shut until next week. I have some trips to do and it's so hard traveling with no music. Can someone plz give me a code or tell me what details you need from me to find the code? I don't know where everyone else is looking for their radio codes as I can't see any radio details and nothing in the manual. Thank you |
New member Username: MissygrrlPost Number: 2 Registered: Aug-15 | I forgot to add that it appears the code can only be a combination of the numbers 1 - 6. I tried putting other codes that have worked for others but they didn't work |
Gold Member Username: DeksterPOLAND Post Number: 2348 Registered: Sep-12 | MissyNZ Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body. contact me: http://koddoradia.pl/ |
New member Username: MissygrrlPost Number: 3 Registered: Aug-15 | Ok I tried to find how to remove the stereo and I couldn't find any way to get it out. Will it help if I give you the car VIN? It's a 2012 Holden barina spark CDX MT Vin: KL3MF48D9BC654873 There's only numbers 1-6 to select from Thank you |
Gold Member Username: DeksterPOLAND Post Number: 2351 Registered: Sep-12 | MissyNZ TRY.... http://www.carstereoremoval.com/ contact me: http://koddoradia.pl/ |
Silver Member Username: Decode_radioPost Number: 915 Registered: Jan-14 | MissyNZ TRY.... http://www.carstereoremoval.com/ contakt me http://forum.kody-radio.pl |
Gold Member Username: Titanum123Post Number: 1354 Registered: Oct-13 | MissyNZ New member Username: Missygrrl http://www.carstereoremoval.com/ contact me: dekcode7@gmail.com |
Gold Member Username: OpelopPost Number: 2660 Registered: Sep-12 | MissyNZ New member Username: Missygrrl http://www.carstereoremoval.com/ ** Paypal account ** .. c.r.t.m.auto@gmail.com |
