Hi all Looking for some help I have just had my battery Replaced on my van and the stereo needs the code Can not find mine Serial no cl040130890371 Model Pu 2294a Appreciate if someone can help
Hello, Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C7000 000 xxxx on a separate label somewhere on the metal casing. (Note ...not beginning with CL.)
