Gold Member Username: IwosPost Number: 1138 Registered: Jul-14 | cesalexio New member Username: Cesalexio Hello, TRY CODE .. 6413 |
New member Username: FiatptPost Number: 3 Registered: Apr-15 | hey, i need the code for my fiat punto radio BP937213808296 Prod Nr. 735272569 |
Gold Member Username: IwosPost Number: 1142 Registered: Jul-14 | Fiatftw New member Username: Fiatpt Hey, TRY CODE .. 3546 |
New member Username: Kenneth1970Post Number: 1 Registered: May-15 | hey, i need the code for my fiat punto radio 735272569 thanks. |
Gold Member Username: Titanum123Post Number: 1181 Registered: Oct-13 | kenneth Remove the radio from the car and after all the letters and numbers on any of the labels, bar codes, and stamped metal body |
New member Username: Kenneth1970Post Number: 2 Registered: May-15 | bp 7342372316 or it could be 7842372316 |
New member Username: Net24Post Number: 1 Registered: May-15 | Radio blaupunkt for fiat muso BP 438340846291 BP-Nr 7644383316 Prod.Nr.Fiat 735387608 Lancia 848 CD/MP3 SW Ver. 2.86 THX |
New member Username: Mich1972Post Number: 1 Registered: May-15 | Hi please could you supply a code for a Fiat Punto BP7649372816 or it might be BP7649372316 the umber is very faded sorry hope you can help if you need any other information please let me know. Many thanks in anticipation |
Gold Member Username: IwosPost Number: 1151 Registered: Jul-14 | NET24 New member Username: Net24 try .. 1551 |
Gold Member Username: IwosPost Number: 1152 Registered: Jul-14 | mich New member Username: Mich1972 Hello, Please could provide you the reference ex; BP9372 12345678 |
New member Username: Mich1972Post Number: 2 Registered: May-15 | Hi Almeida the reference number is ether BP 7649 372816 or BP 7649 372316 Were not sure if the 3rd from the last digit is a 8 or a 3 as the label on the radio is very faded. Thanks }} |
New member Username: XilosPost Number: 1 Registered: May-15 | Hi all I'd be very grateful for any help that anybody can give me in providing me with a code to unlock my car's radio, since I had to replace its battery and cannot find the code anywhere! Its details on its labels and side panels are as follows; Philips 22 RC 465/65 Ref. Peugeot 14 800 360 80 PHAPEFW9036758 9022 314 65659 M/ch: 037089 Any help would be much appreciated..thanks |
Gold Member Username: IwosPost Number: 1153 Registered: Jul-14 | Vitalij P New member Username: Xilos Hello, TRY CODE .. 1655 |
New member Username: XilosPost Number: 2 Registered: May-15 | Thank you ALMEIDA! The code worked! You save mi life I have a question to you. I have 2 old ones blaupunkt from my first car and i forgot the code from them, is it possible ask you to help to get them. i will post photos of labels from sides. first two pictures is from first, from 3 to 4 picture is from second one. Thank you for help! |
Gold Member Username: IwosPost Number: 1155 Registered: Jul-14 | Vitalij P New member Username: Xilos Hello, Sorry, I can give you a code about 6 months Contact me here - (c.r.t.m.auto@gmail.com) |
New member Username: Mich1972Post Number: 3 Registered: May-15 | Hi please can you provide the code for a fiat punto 2000 radio Reference BP9372Y3616579 Many Thanks |
New member Username: PiotrPost Number: 1 Registered: May-15 | helo i need the code for my fiat punto radio BP 937213856309 BP.Nr. 7 649 372 316 |
Gold Member Username: Titanum123Post Number: 1185 Registered: Oct-13 | piotrekwroc New member Username: Piotr try code 6514 |
Gold Member Username: IwosPost Number: 1161 Registered: Jul-14 | mich New member Username: Mich1972 Hello, TRY CODE .. 6514 |
New member Username: MarraPost Number: 1 Registered: May-15 | Hi guys, My fiat punto blaupunkt radio blocked for unknown reasons... The guy from my garage gave me the following codes: BP7642375316 Fiatnr735337934 Are these the correct codes? Can somebody help me finding the code for my radio? Thanks a lot Marra |
Gold Member Username: Titanum123Post Number: 1199 Registered: Oct-13 | Marra New member Username: Marra Serial number Example: BP2375X1234567 |
New member Username: Deebee96Post Number: 1 Registered: May-15 | Hi guys just bought my fiat punto and took the radio out to replace it but the new one doesn't fit and all the codes have been scraped off. My serial number is bp937213850692 and bp-nr is 7649372316 And prod.nr 735289639 Thanks if anyone can help. |
Gold Member Username: Titanum123Post Number: 1202 Registered: Oct-13 | Deebee New member Username: Deebee96 try code 3513 |
Gold Member Username: IwosPost Number: 1177 Registered: Jul-14 | Deebee New member Username: Deebee96 Hello, TRY CODE .. 3513 |
New member Username: BoerePost Number: 1 Registered: May-15 | Hello guys, Replaced the battery of my Punto and now it asks for the radio code. It is a Blaupunkt 815 with serial number: BP237534088119 Can you help me with the code? Thanks! |
Gold Member Username: Titanum123Post Number: 1203 Registered: Oct-13 | boere New member Username: Boere try code 4415 |
New member Username: BoerePost Number: 2 Registered: May-15 | Hi qwerty, Thanks, the code works! |
New member Username: AlanmPost Number: 1 Registered: May-15 | Hi I have a Blaupunkt Car 2003 radio for my Corsa. GM020317630157 7649200321 Anyone able to provide safe code? Thanks |
Silver Member Username: Decode_radioPost Number: 740 Registered: Jan-14 | AM New member Username: Alanm CODE 2601 contakt me http://forum.kody-radio.pl |
New member Username: AlanmPost Number: 2 Registered: May-15 | Thanks, code works. |
New member Username: Deebee96Post Number: 2 Registered: May-15 | Great, thanks a lot guys it worked |
New member Username: Mikeyboy235Post Number: 1 Registered: May-15 | Hi all, new member here. Hoping someone might be able to help me with my stereo code? It has 4252 written in marker on the stereo, but that code doesn't work. Thanks in advance! Mikey |
Gold Member Username: Titanum123Post Number: 1205 Registered: Oct-13 | Mikey New member Username: Mikeyboy235 try code 5413 |
New member Username: Mikeyboy235Post Number: 2 Registered: May-15 | Thank you! 5413 worked, however, now I have the error message "CANCHECK". (Do I need to post elsewhere for this?) Thanks! Mikey |
New member Username: Peter1988Post Number: 3 Registered: May-15 | Hi there, Could someone please help me generatie the for my FIAt Punto radio. Thank you very much in advance. My number is 815BP237534099505 |
Gold Member Username: IwosPost Number: 1190 Registered: Jul-14 | Peter1988 New member Username: Peter1988 Hello, Duplicate post....Already answered |
New member Username: Mich1972Post Number: 4 Registered: May-15 | ALMEIDA Gold Member Username: Iwos Post Number: 1161 Registered: Jul-14 Posted on Monday, May 18, 2015 - 16:18 GMT mich New member Username: Mich1972 Hello, TRY CODE .. 6514 Worked a treat thanks |
New member Username: AhmedovPost Number: 1 Registered: May-15 | hello would you plz help me i need code for my fiat punto 2002 bp937227268932 thank you so much |
Silver Member Username: Decode_radioPost Number: 745 Registered: Jan-14 | ahmed New member Username: Ahmedov CODE 3353 contakt me http://forum.kody-radio.pl |
New member Username: Puno8511Post Number: 1 Registered: May-15 | Hello i need help. I have a Punto from 1999 without Radio-Code... BP7649372316 Thank you very much. |
Gold Member Username: IwosPost Number: 1220 Registered: Jul-14 | Puno_Eva New member Username: Puno8511 Hello, Serial number Example: BP9372X1234567 |
New member Username: Puno8511Post Number: 3 Registered: May-15 | Iam sorry now i found it: Bp9372x0801277 Thank you |
Gold Member Username: IwosPost Number: 1221 Registered: Jul-14 | Puno_Eva New member Username: Puno8511 Re; TRY CODE .. 6151 |
New member Username: Antonyc1994Post Number: 1 Registered: Jun-15 | Hey I need my code for my grande punto 07 Blaupunkt radio Code is: 73780040363 Oder Flat 199mp3mysb05 Thankyou |
Gold Member Username: Titanum123Post Number: 1227 Registered: Oct-13 | Antonyc1994 New member Username: Antonyc1994 Serial number Example; BPXXXXXXX |
New member Username: Antonyc1994Post Number: 2 Registered: Jun-15 | Sorry I've just found the code its BP -Nr 7 647 386 316 Fiat -nr 735 386 316 Is that the right 1? Thanks for the help |
Gold Member Username: IwosPost Number: 1228 Registered: Jul-14 | Antonyc1994 New member Username: Antonyc1994 Hello, Serial number Example: BP7386 X 1234567 |
New member Username: Antonyc1994Post Number: 3 Registered: Jun-15 | I'm sorry is it 815bp738673586586 ?? I'm sorry if I've give the wrong 1 again and thankyou for the help |
Gold Member Username: IwosPost Number: 1229 Registered: Jul-14 | Antonyc1994 New member Username: Antonyc1994 Hello, TRY CODE .. 5445 |
New member Username: SfolhaPost Number: 1 Registered: Jun-15 | Hello, I need the code to my Blaupunkt fiat punto radio: BP2750P7447838 Thanks. |
Gold Member Username: IwosPost Number: 1230 Registered: Jul-14 | Serafim New member Username: Sfolha Hello, TRY CODE .. 0358 |
New member Username: SfolhaPost Number: 3 Registered: Jun-15 | Hi, works for me. Thanks. |
New member Username: AhmedovPost Number: 2 Registered: May-15 | the code 3353 didnt work my code is bp937227268932 |
Gold Member Username: IwosPost Number: 1245 Registered: Jul-14 | ahmed New member Username: Ahmedov Instructions http://www.dndservices.co.uk/fiat_punto-low.html |
New member Username: DavebpPost Number: 1 Registered: Jun-15 | Hi guys, I tried all the calculators I could find, but really need your help.. BP nr 7649372316 Prod nr 735272569 Serial BP937213842128 Thank you! Much appreciated! |
Gold Member Username: IwosPost Number: 1255 Registered: Jul-14 | DaveBP New member Username: Davebp Hello, TRY CODE .. 6523 CONTACT me: C.R.T.M.auto@gmail.com |
New member Username: DavebpPost Number: 2 Registered: Jun-15 | Mint!! Thanks a lot! The code worked! Super awesome! |
New member Username: VerobyPost Number: 1 Registered: Jun-15 | Hello I need the code for blaupunkt cassette fiat Punto Serial BP937227277918 |
Gold Member Username: IwosPost Number: 1267 Registered: Jul-14 | Karim New member Username: Veroby Hello, TRY CODE .. 4234 |
New member Username: VerobyPost Number: 2 Registered: Jun-15 | Code 4234 not working |
Gold Member Username: DeksterPOLAND Post Number: 2211 Registered: Sep-12 | Karim is the correct code for the Serial Number (BP937227277918) contact me: http://koddoradia.pl/ |
New member Username: EliaspeedPost Number: 1 Registered: Jun-15 | Hi can anyone help me with a radio code for Blaupunkt BP237448054412 PART NUMBER 7642374316 THANKS |
Gold Member Username: OpelopPost Number: 2469 Registered: Sep-12 | Eliaspeed New member Username: Eliaspeed code 4645 contact to me radiocodeservice@gmail.com |
New member Username: EliaspeedPost Number: 2 Registered: Jun-15 | opelop thanks alot |
New member Username: Ardveen_2015Post Number: 1 Registered: Jun-15 | Hi. Could some one help me! I need the code for my fiat punto blaupunkt radio. BP535457379361 8635123208.2 Many thanks |
Gold Member Username: IwosPost Number: 1274 Registered: Jul-14 | ardveen2015 New member Username: Ardveen_2015 Hello, TRY CODE .. 1511 |
New member Username: 180jacobPost Number: 1 Registered: Jun-15 | Hi All, Does someone mind looking up a code for me please: car:fiat 500 model:Fiat 312 MP3 SB05 model:7 646 383 316 serial:815BP638389553050 Thank you very much, Jacob |
Silver Member Username: Decode_radioPost Number: 755 Registered: Jan-14 | 180Jacob New member Username: 180jacob CODE 5245 contakt me http://forum.kody-radio.pl |
New member Username: 180jacobPost Number: 2 Registered: Jun-15 | thanks 'decode radio' will try it in the morning. Thanks again, Jacob |
New member Username: 180jacobPost Number: 3 Registered: Jun-15 | Worked perfectly, Thankyou!!! |
New member Username: KellepacaPost Number: 1 Registered: Jun-15 | Hi all, I need a code for Fiat 199 MP3 The information on the side is: 815 BP632965698353 7 646 329 316 034502 Thanks in advance |
Gold Member Username: IwosPost Number: 1285 Registered: Jul-14 | Kelle Paca New member Username: Kellepaca Hello, TRY CODE .. 4635 |
New member Username: KellepacaPost Number: 2 Registered: Jun-15 | Dear Almeida, The code worked perfectly. Thank you very much. |
New member Username: LuckyboyLeskovac, Serbia Serbia Post Number: 1 Registered: Jun-15 | Can anybody help me with fiat punto auto radio code??? Product no:7 649 372 316 Serial no: BP937213822113 Thank you in advance |
Gold Member Username: Titanum123Post Number: 1253 Registered: Oct-13 | lucky boy New member Username: Luckyboy try code 5263 contact me: dekcode7@gmail.com |
Gold Member Username: OpelopPost Number: 2486 Registered: Sep-12 | lucky boy New member Username: Luckyboy try code 5263 contact to me radiocodeservice@gmail.com |
New member Username: LuckyboyLeskovac, Serbia Serbia Post Number: 2 Registered: Jun-15 | Thank you guys, I'm still waiting for "wait" error to reset... Hope it will work.. I'll keep you informed! Thank you as lot!!! |
New member Username: LuckyboyLeskovac, Serbia Serbia Post Number: 3 Registered: Jun-15 | Thank you guys, I'm still waiting for "wait" error to reset... Hope it will work.. I'll keep you informed! Thank you a lot!!! |
New member Username: LuckyboyLeskovac, Serbia Serbia Post Number: 4 Registered: Jun-15 | It's alive!!! Code is working, thank you guys: qwerty Gold Member Username: Titanum123 & opelop Gold Member Username: Opelop |
New member Username: LemiPost Number: 1 Registered: Jun-15 | Please help Fiat Panda serial: BP338974296851 blaupunkt |
Gold Member Username: IwosPost Number: 1293 Registered: Jul-14 | lemi New member Username: Lemi try .. 1463 |
New member Username: UzelPost Number: 2 Registered: Jun-15 | Hi, Please code for fiat panda. 815 BP338548906624 Fiat 169 CD 7 643 385 316 Thanks! |
Gold Member Username: Titanum123Post Number: 1255 Registered: Oct-13 | Uzel New member Username: Uzel try code 4642 contact me: dekcode7@gmail.com |
Gold Member Username: OpelopPost Number: 2488 Registered: Sep-12 | Uzel New member Username: Uzel try code 4642 contact to me radiocodeservice@gmail.com |
New member Username: VerooPost Number: 1 Registered: Jun-15 | Hello I need the code for blaupunkt cassette fiat Punto Serial BP937227277918 |
Gold Member Username: Titanum123Post Number: 1259 Registered: Oct-13 | veroo New member Username: Veroo try code 4234 contact me: dekcode7@gmail.com |
Silver Member Username: Decode_radioPost Number: 776 Registered: Jan-14 | chemical brother New member Username: Chemical_brother CODE 4234 contakt me http://forum.kody-radio.pl |
Gold Member Username: DeksterPOLAND Post Number: 2232 Registered: Sep-12 | chemical brother CODE 4234 contact me: http://koddoradia.pl/ |
New member Username: PorkePost Number: 1 Registered: Jun-15 | Fiat punto 2004years: BP237546895913. 7642375316 |
Gold Member Username: OpelopPost Number: 2499 Registered: Sep-12 | code 2151 contact to me radiocodeservice@gmail.com |
New member Username: Aras111Post Number: 1 Registered: Jun-15 | Can you help me with iveco radio? 815BP700573750789 7607005082 Thanx |
Gold Member Username: OpelopPost Number: 2508 Registered: Sep-12 | Aras111 New member Username: Aras111 code 2411 contact to me radiocodeservice@gmail.com |
New member Username: Aras111Post Number: 2 Registered: Jun-15 | It works. Thank you very much |
New member Username: MarraPost Number: 2 Registered: May-15 | Hi guys, Second try. 815 BP 237534121940 Bp nr: 7642375316 Can somebody help me? Thanks!! |
Gold Member Username: IwosBR- Gloria Post Number: 1308 Registered: Jul-14 | Marra New member Username: Marra Hello, TRY CODE .. 2422 |
Gold Member Username: Titanum123Post Number: 1268 Registered: Oct-13 | Marra New member Username: Marra try code 2422 contact me: dekcode7@gmail.com |
New member Username: MarraPost Number: 3 Registered: May-15 | Thanks guys, will try after my holidays. |
New member Username: Ianmc999Post Number: 1 Registered: Jun-15 | Hi could someone please help me with a code for the following : - BP237534102672 7 642 375 316 Thank you |
Gold Member Username: DeksterPOLAND Post Number: 2252 Registered: Sep-12 | ian CODE 4526 contact me: http://koddoradia.pl/ |
New member Username: Numero6Post Number: 1 Registered: Jun-15 | Hi could you help with a code for the following please: BP1430Y4470692 7 612 001 433 Thank you |
