Citroen dispatch radio code.
Username: Moosecowhead
Has anybody got the code for my 55 plate citroen dispatch standard radio.
Model no.... Pu-2294a©
Serial no..... Cl040150987514c
Username: Dekster
POLAND
Post Number: 2221
Tom
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
contact me: http://koddoradia.pl/
There are no other labels or codes on there. It also doesn't say it's made by clarion it just says citroen on the front.
Can anybody help me please I still can't get it to work.
