New member Username: TonyceePost Number: 1 Registered: Jan-15 | Hi every one !, could you please help ,a friend of mine has a peugeot 206 and he needs the radio code! its a very old non led display model with just 6 buttons to enter the code ,serial number is BP8146X3335359 many thanks in advance |
Silver Member Username: Titanum123Post Number: 903 Registered: Oct-13 | tony New member Username: Tonycee try code 5324 |
New member Username: TreaxPost Number: 1 Registered: Jan-15 | Hi all id love a code for my radio part num.. 7643383316 serial..BP338341142503 thanks for any help |
Silver Member Username: IwosPost Number: 630 Registered: Jul-14 | monkey New member Username: Treax Hi, TRY CODE .. 2316 |
New member Username: TreaxPost Number: 2 Registered: Jan-15 | yes it worked ,thankyou for quick reply |
New member Username: MetausPost Number: 4 Registered: Feb-14 | Hi, If someone is able to help me retrieve a radio code I would be forever grateful! It's for a Blaupunkt 520 Serial number: BP8385X1712146 Product number: 92057951U1E I hope this is the right spot for this post. Thank you for your help in advance ![]() |
New member Username: MetausPost Number: 5 Registered: Feb-14 | Hi, If someone is able to help me retrieve a radio code I would be forever grateful! It's for a Blaupunkt 520 Serial number: BP8385X1712146 Product number: 92057951U1E I hope this is the right spot for this post. Thank you for your help in advance |
New member Username: MidojorjPost Number: 1 Registered: Jan-15 | Hi trying to find code my blaunpunkt 568 serial BP224031707490 product no 92084568 |
Silver Member Username: Titanum123Post Number: 906 Registered: Oct-13 | liz New member Username: Midojorj try code 2332 |
New member Username: J_leePost Number: 1 Registered: Jan-15 | Hi, everyone. I am looking for a radio code for a Nissan ET Radio RH with s/n: BP9349 47660145, Part no: 7 649 349 318. Thank you in advance. |
Silver Member Username: IwosPost Number: 634 Registered: Jul-14 | Roger New member Username: J_lee Hi, TRY CODE .. 6144 |
New member Username: J_leePost Number: 2 Registered: Jan-15 | Thank you so much! I will try it. |
New member Username: DarkoredaPost Number: 1 Registered: Feb-15 | hello please help me i lost my code 815 BP 237534072528 7642375316 tnx |
Silver Member Username: IwosPost Number: 799 Registered: Jul-14 | darkoreda New member Username: Darkoreda Hello, TRY CODE .. 6613 |
New member Username: DarkoredaPost Number: 2 Registered: Feb-15 | almeida genius!!! tnx |
New member Username: DirtypeterPost Number: 1 Registered: Feb-15 | Hi could you help me, please? I'm looking for a code for my blaupunkt car radio. Peugeot 307sw (2005) Serial number: BP503852513818 part number: 7645038392 Thank you! |
Silver Member Username: IwosPost Number: 806 Registered: Jul-14 | dirtypeter New member Username: Dirtypeter Hello, TRY CODE .. 5622 |
New member Username: DirtypeterPost Number: 2 Registered: Feb-15 | almeida awesome thank you!! |
New member Username: DekoPost Number: 1 Registered: Feb-15 | Hi, searching for code of bought car-radio. Who can help me please?? Blaupunkt Travelpilot BP030344368562 E2 7 612 301 340 Thanks a lot for any help!!! |
Silver Member Username: Titanum123Post Number: 981 Registered: Oct-13 | Deko New member Username: Deko try code 9789 |
New member Username: DekoPost Number: 2 Registered: Feb-15 | code 9789 doesn't work :-( |
New member Username: DekoPost Number: 3 Registered: Feb-15 | any other possibilities? :-( |
Silver Member Username: IwosPost Number: 810 Registered: Jul-14 | Deko New member Username: Deko try .. 8035 |
New member Username: AntoniobanderasPost Number: 1 Registered: Feb-15 | Hi every body, I've also locked my fiat punto blaupunkt radio.. please help me.. SERIAL NR. BP9372 1384 4088 PART NR. 7649 372316 PRODUKT NR FIAT 735272569 Please help me. |
Silver Member Username: Decode_radioPost Number: 552 Registered: Jan-14 | antoniobanderas New member Username: Antoniobanderas CODE 5145 contakt me http://forum.kody-radio.pl |
New member Username: BituPost Number: 1 Registered: Feb-15 | Hola a todos Me gustaria que me facilitaran el c�digo de la radio del Opel Astra de mi padre, que la casa no se lo quiere dar. La radio es Blaukpunt CAR300F 90 533 422 GM030M15935910 Muchas Gracias Diculpad el idioma, pero no se de otra forma |
Silver Member Username: IwosPost Number: 813 Registered: Jul-14 | juan New member Username: Bitu Hola, Try Code .. 1824 |
New member Username: BituPost Number: 2 Registered: Feb-15 | Much�simas gracias. Funciona perfecto. Me has salvado llevaba tres meses sin radio. Por cierto yo tambi�n me apellido Almeida. Saludos |
New member Username: DekoPost Number: 4 Registered: Feb-15 | Almeida.....you' re amazing!!!! Thanks a lot !!!!! |
Silver Member Username: IwosPost Number: 821 Registered: Jul-14 | Deko New member Username: Deko Hello, Thanks |
New member Username: Simmo3801Post Number: 1 Registered: Feb-15 | Hi I have a 2010 Nissan Note which I need the radio code for if anyone can help please? BP8348A1084207 7648348318 Thank you in advance |
Silver Member Username: IwosPost Number: 836 Registered: Jul-14 | simmo New member Username: Simmo3801 Hello, TRY CODE .. 2168 |
New member Username: Simmo3801Post Number: 2 Registered: Feb-15 | Excellent Almeida thank you, I have a working radio again!!! |
New member Username: DakaPost Number: 1 Registered: Mar-15 | Hi! I need the code for Blaupunkt Car 300 F. Opel Astra G (2001) GM030M15919976 7649852520 Thanks a lot for any help! |
Silver Member Username: Decode_radioPost Number: 618 Registered: Jan-14 | daka New member Username: Daka CODE 1282 contakt me http://forum.kody-radio.pl |
New member Username: DakaPost Number: 2 Registered: Mar-15 | decode radio Silver Member Username: Decode_radio Yes, it works.. Thank you so much!! |
New member Username: AlorssenPost Number: 1 Registered: Mar-15 | Hola a tod@s, tengo un Nissan Micra y necesito el codigo de la radio ya que desconecte la bateria y ahora me lo pide. Blaupunkt 7642347318 BP234746089000 Muchas gracias de antemano!!! |
Silver Member Username: IwosPost Number: 920 Registered: Jul-14 | Alorssen New member Username: Alorssen Hola, TRY CODE .. 0739 |
New member Username: EvilmonkeyPost Number: 1 Registered: Mar-15 | Hi. I have a 60 plate ford transit with a blaupunkt stereo, the sat Nav one and I need the unlock code. Serial number 7 612 330 584 If anyone can help it would be muchly appreciated, thanks. |
Silver Member Username: IwosPost Number: 923 Registered: Jul-14 | danny New member Username: Evilmonkey Hello, Viewed here.. http://www.radiocode.ivgsoft.com/img/img03/bp_01_003.gif |
New member Username: YkatoausPost Number: 1 Registered: Mar-15 | Hi, Please anyone help me with the code for blaupunkt 520. The car is a Holden Astra CD 2000, There is following mention in the upper part of the car audio. BLAUPUNKT Bosch Group No.:92 057 951 Type:Blaupunkt 520 U1E BP8391Y3014543 Thank you in advance. |
Gold Member Username: DeksterPOLAND Post Number: 2090 Registered: Sep-12 | yasu CODE 5640 contact me: http://koddoradia.pl/ |
New member Username: FreshdumbledorePost Number: 1 Registered: Mar-15 | Hey Guys, i need some help.. when i changed the batterie of my car, the radio was locked and i can't find the code.. The radio is a Blaupunkt car 300 (F) GM Serial Number: GM030M 33814190 7 640 852 520 I really hope someone can help me |
Silver Member Username: Decode_radioPost Number: 626 Registered: Jan-14 | Fresh Dumbledore New member Username: Freshdumbledore CODE 6861 contakt me http://forum.kody-radio.pl |
New member Username: FreshdumbledorePost Number: 2 Registered: Mar-15 | decode radio Silver Member Username: Decode_radio Wow thank you so much! |
New member Username: Martin1123Post Number: 3 Registered: Mar-15 | Can someone help me Blaupunkt CD30 7 643 104 311 GM003053221362 |
New member Username: YkatoausPost Number: 2 Registered: Mar-15 | Hi Dekster, Thank you. You saved me a lot of trouble. regards, yasu |
Silver Member Username: Decode_radioPost Number: 628 Registered: Jan-14 | Martin juu New member Username: Martin1123 immo locked radio linked to car we cant help contakt me http://forum.kody-radio.pl |
New member Username: PixxPost Number: 1 Registered: Mar-15 | Hi! Please help radio code volkswagen Blaupunkt Gamma t4 7 648 237 360 vwz1z3x0620050 |
Silver Member Username: IwosPost Number: 958 Registered: Jul-14 | ssk New member Username: Pixx Duplicate post, already answered |
New member Username: Stan2005_iePost Number: 1 Registered: Mar-15 | Hi Guys, I was hoping someone could help with code. I have an opel astra 1998. need code for Blaupunkt Radio 300. Details below| GM1300V4066289 7647852320 Thanks Ed |
Silver Member Username: IwosPost Number: 961 Registered: Jul-14 | Ed New member Username: Stan2005_ie Hello, TRY CODE .. 6337 |
New member Username: Stan2005_iePost Number: 2 Registered: Mar-15 | Hi Almeida, Thank you so much. Worked perfectly! Cheers Ed |
New member Username: DboPost Number: 1 Registered: Mar-15 | I need radio code for blaupunkt 520 My serial number is BP2391 3 0873383 Other number is 7642391510 Many thanks |
Gold Member Username: DeksterPOLAND Post Number: 2103 Registered: Sep-12 | Petr CODE 3664 contact me: http://koddoradia.pl/ |
New member Username: DboPost Number: 2 Registered: Mar-15 | Thank you worked perfectly |
New member Username: TruckjackPost Number: 1 Registered: Mar-15 | hi can anyone help me please my battery died on myy 04 Nissan micra an decode it number are bp334947250119 7643349318 thanks for helping |
Silver Member Username: IwosPost Number: 971 Registered: Jul-14 | truckjack New member Username: Truckjack Hello, TRY CODE .. 3216 |
Gold Member Username: Titanum123Post Number: 1059 Registered: Oct-13 | truckjack New member Username: Truckjack try code 3216 |
New member Username: TruckjackPost Number: 2 Registered: Mar-15 | thanks for the code haven't try it waiting for radio to stop showing wait for 1 hour |
New member Username: Jersh1Post Number: 1 Registered: Apr-15 | Hi, everyone. I am looking for a radio code for a Nissan ET Radio RH with s/n: BP9349 12619456, Part no: 7 649 349 318. Thank you in advance Eyal |
Gold Member Username: DeksterPOLAND Post Number: 2117 Registered: Sep-12 | EYAL CODE 2559 contact me: http://koddoradia.pl/ |
New member Username: Jersh1Post Number: 2 Registered: Apr-15 | Many thanks !!!! the radio is in "secure" mode, How do I put the code in ? (the radio channels are only 1-6. do I need to insert the radio to "receive code" mode ? Many thanks again !! Eyal |
Gold Member Username: DeksterPOLAND Post Number: 2122 Registered: Sep-12 | EYAL Code Entry as Follows: Switch Radio On - Display Shows " CODE " Press preset " 1 " repeatedly for 1st Digit Press preset " 2 " repeatedly for 2nd Digit Press preset " 3 " repeatedly for 3rd Digit Press preset " 4 " repeatedly for 4th Digit If the correct code number is now shown Press Tuning Up Button " ^ " To Enter contact me: http://koddoradia.pl/ |
New member Username: Jersh1Post Number: 3 Registered: Apr-15 | Dekster, But the display shows "secure" how do I change it to "code" mode ? |
Gold Member Username: DeksterPOLAND Post Number: 2123 Registered: Sep-12 | EYAL sorry we can't help Main Dealer or a Decoding Service only for this code SECURE This stereo is electronically paired to the engine management system of the vehicle it came out of using very sophisticated technology. When it is first powered up, it will communicate with the vehicle, and a message of "WAIT" will appear whilst this process is in operation. If communication has been successfull, it will prompt for the code number to be entered. However, if removed and refitted into a different vehicle other than the original one, it will not recognise the coded signals of the new car, and will instead display an error message of "SECURE". contact me: http://koddoradia.pl/ |
New member Username: BenjamminPost Number: 1 Registered: Apr-15 | Hey, looking for code for a Renault Blaupunkt stereo s/n: BP4496U7102150 part no: 7 644 496 091 Thanks in advance, Benjamin |
Silver Member Username: Decode_radioPost Number: 670 Registered: Jan-14 | Benjamin New member Username: Benjammin CODE 2808 contakt me http://forum.kody-radio.pl |
New member Username: AsguardPost Number: 1 Registered: Apr-15 | Hi Guys, Require assist. Year. 2003 Blaupunkt, GM, Bosch Group. No.: 92 084 568 Type: SYS 1 BP2240 2 1637994 Other numbers on case: LP 8 635 123 2471 (right side case) LP 8 635 123 246 2 (left side case) Thanks |
Gold Member Username: DeksterPOLAND Post Number: 2128 Registered: Sep-12 | asguard CODE 1513 contact me: http://koddoradia.pl/ |
New member Username: AsguardPost Number: 2 Registered: Apr-15 | Thank you Dekster. Worked like a charm. Great service. Once again, many thanks. All the best. |
New member Username: OxiaPost Number: 1 Registered: Apr-15 | Hi, everyone. I am looking for a radio code for a Nissan Micra (2005) Radio MM CD-J with s/n: 234 756 229 986, Part no: 7 642 347 318. Thank you in advance Patrick |
Gold Member Username: IwosPost Number: 1011 Registered: Jul-14 | Patrick New member Username: Oxia Hello, TRY CODE .. 7955 |
New member Username: ElodiePost Number: 2 Registered: Apr-15 | Hi everyone, We are desperate to find our radio code of our peugeot 206 :/ please help us Informations we get on our radio : Blaupunkt T1 Low 7 648 140 392 BP814017883189 Thanks for your help, Regards, Elodie |
New member Username: ElodiePost Number: 3 Registered: Apr-15 | Hi everyone, We are desperate to find our radio code of our peugeot 206 :/ please help us Informations we get on our radio : Blaupunkt T1 Low 7 648 140 392 BP814017883189 Thanks for your help, Regards, Elodie |
New member Username: ElodiePost Number: 4 Registered: Apr-15 | Hi everyone, We are desperate to find our radio code of our peugeot 206 :/ please help us Informations we get on our radio : Blaupunkt T1 Low 7 648 140 392 BP814017883189 Thanks for your help, Regards, Elodie |
New member Username: ElodiePost Number: 5 Registered: Apr-15 | Oops sorry bug with my phone :/ |
Gold Member Username: IwosPost Number: 1014 Registered: Jul-14 | Elodie New member Username: Elodie Duplicate post, already answered |
New member Username: OxiaPost Number: 2 Registered: Apr-15 | Hello, Very lot of thanks about efficacity and Quick respons (9 minutes after the question) Thank you, Almeida. |
New member Username: OxiaPost Number: 3 Registered: Apr-15 | precision: radio code work very well. |
New member Username: JojoboboPost Number: 1 Registered: Apr-15 | Hello everyone and well done for all the people helping to find missing radio codes. Now I need some help please. I have an Audi a3 with a Audi concert radio I have checked to see it is a blaupunkt radio. The serial number is AUZ1Z3G9237951 can somebody, anybody help? X Very much appreciated if someone could help x thank you x |
Silver Member Username: Decode_radioPost Number: 682 Registered: Jan-14 | jo bobbins New member Username: Jojobobo sorry we can't help Main Dealer or a Decoding Service only for this code contakt me http://forum.kody-radio.pl |
New member Username: JojoboboPost Number: 2 Registered: Apr-15 | Thanks for the quick reply, the main dealership wants �20 so but apparently it should be free. So someone suggested this website. I don't understand about decoding service. Where can I get this service? Is it the kody radio link? Does it cost any money and if so, how much? Thanks again x |
New member Username: AkstairsPost Number: 1 Registered: Apr-15 | hi everyone I need a code to a blaupunkt 420 stereo No 92 057 948 Serial number BP8390x1722198 I would be very grateful if someone could help me with this Thankyou so much in advance |
Gold Member Username: IwosPost Number: 1027 Registered: Jul-14 | akstairs New member Username: Akstairs Hello, TRY CODE .. 3720 |
New member Username: Bekoo88Post Number: 2 Registered: Apr-15 | Please help I need code for my blaupunkt type : sys 3B NO. : 92084573 S.N :BP2250 6 4263687 NO. : 7642250520 thanks in advance |
Gold Member Username: Titanum123Post Number: 1155 Registered: Oct-13 | bekoo88 New member Username: Bekoo88 try code 6335 |
New member Username: Lrussell89Post Number: 1 Registered: May-15 | I have a Peugeot 206 and need code for bblaupunkt t1 low serials are: BP8140W8799902 and 7648140392 Let me know ASAP thanks lee |
Gold Member Username: IwosPost Number: 1082 Registered: Jul-14 | lee New member Username: Lrussell89 try .. 2164 |
New member Username: Bekoo88Post Number: 3 Registered: Apr-15 | awesome thanks |
New member Username: MgulalPost Number: 1 Registered: May-15 | Hi every one !, could you please help ,I mine have a renault and I need the radio code! its a very old non led display model. My radio model is Blaupunkt CAR 300 (F) NO:24455376 Serial number is GM030M33866332 many thanks in advance |
Gold Member Username: IwosPost Number: 1141 Registered: Jul-14 | mehmet gulal New member Username: Mgulal Hello, TRY CODE .. 6528 |
New member Username: Neo131313Post Number: 1 Registered: May-15 | Hi All, new member as well here! I have a Blaupunkt CAR 300 (f) Number: 90 533 422 Serial: GM030MY5815470 I got from a used car that had no code on it. Can you please be kind enough and help providing me a code? Thanks a million in advance |
Gold Member Username: IwosPost Number: 1144 Registered: Jul-14 | Neo131313 New member Username: Neo131313 Hello, TRY CODE .. 9388 |
New member Username: FenerbahcePost Number: 8 Registered: Feb-15 | 7 648 245 380 AUZ1Z2X6682295 CODE.... |
Gold Member Username: IwosPost Number: 1148 Registered: Jul-14 | Mevlut New member Username: Fenerbahce sorry we can't help Main Dealer or a Decoding Service only for this code |
New member Username: Kilty71Post Number: 1 Registered: May-15 | Hi i wonder if you can help me. totally lost.I have just bought a second hand 2003 nissan micra k12. i cannot find any serial numbers and the previous owner said they put in a new battery,all the codes i can find dontseem to be correct. The only serial numbers i can find to do with my radio are as follows~ K121138588 C17129568498 03095013 and etched on the back of the radio are:- 8 635 123 206 0 4 St 12 ZE 25/25-03 PHCR or P11CR or PNCR hard to make out. Please help |
Silver Member Username: Decode_radioPost Number: 730 Registered: Jan-14 | Kilty New member Username: Kilty71 photo with serial numbers please contakt me http://forum.kody-radio.pl |
New member Username: Kilty71Post Number: 4 Registered: May-15 | This is the only picture I have![]() |
New member Username: Kilty71Post Number: 5 Registered: May-15 | This is the only picture I have |
Silver Member Username: Decode_radioPost Number: 733 Registered: Jan-14 | Kilty New member Username: Kilty71 remove radio from car and serial numbers from radio please contakt me http://forum.kody-radio.pl |
