New member Username: Knightlore2208Post Number: 1 Registered: May-15 | Hi there, Just brought the car,the battery must have been disconnected at some point, the previous owner had lost the radio code. Could you please help. Model PU-2294A © Serial CL0401Y0381566 other numbers on the label if you need them: FMG 24 286-8497-33 e 13020410 Thx in advanced. |
Silver Member Username: Decode_radioPost Number: 718 Registered: Jan-14 | wayne New member Username: Knightlore2208 Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contakt me http://forum.kody-radio.pl |
