Cabasse Auditorium Tronic Code needed
Username: Smaltleys
Hi,
please, anybody can help me?
I changed the battery of my Renault Espace and now it asks for a 4 digit code for the Cabasse Auditorium Tronic.
Barcode: 8 200 089 153 T K459
Many thanks in advance
Username: Iwos
Post Number: 1089
smalty
Username: Smaltleys
Hello,
TRY CODE .. 5114
Username: Smaltleys
Hi Almeida,
Many thanks for your prompt answer.
Unfortunately the code did not work (error message popped up).
The barcode I gave you is from the front unit, I reckon that is correct place.
Username: Iwos
Post Number: 1090
smalty
Username: Smaltleys
Hi,
What you give is your load 6 cd's
Need us the reference on your receiver ( Ampli-Tuner).
That start with 8 200 205 833 or 8 200 338 598 more security code.
Username: Smaltleys
Hi Almeida,
Sorry about that.
Receiver reference is
8 200 205 833 T F619
Many thanks
Username: Iwos
Post Number: 1092
smalty
Username: Smaltleys
Hello,
TRY CODE .. 3552
Username: Smaltleys
Hi Almeida,
That worked perfectly.
Thanks a lot!
