New member Username: WolfyPost Number: 2 Registered: Apr-15 | Help I have lost radio code for my citreon car radio model no pu-2294a serial no cl040140931768c can u help |
Gold Member Username: DeksterPOLAND Post Number: 2134 Registered: Sep-12 | Wolfy Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + on a separate label somewhere on the metal casing. (Note ...not beginning with CL.) If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio. contact me: http://koddoradia.pl/ |
