Car radio code
Username: Wolfy
Hi can u help I lost radio code for citreon serial no cl040140931768c when I fitted new battery thanks
Username: Titanum123
Post Number: 1100
Wolfy
Username: Wolfy
Your radio is made by CLARION and the only CLARION code that can be calculated (using a serial number ) anywhere on the Internet is if your radio also has a BARCODE SERIAL NUMBER beginning with C 7000000 + + + + + + on a separate label somewhere on the metal casing.
(Note ...not beginning with CL.)
If not then it will only be available from your Main Dealer or a Decoding Service or your local Car Radio / Audio Store who will connect a laptop to read/recode the memory chip (EEPROM) inside your radio.
