Radio code
Username: Scoobydoo
Need code for wife's Renault megane as changed battery model no 22DC277/62 Can you help plz cheers
Username: Iwos
Post Number: 935
darren
Username: Scoobydoo
Duplicate post....Already answered
Username: Jk125
I have recently bought a Renault scenic and radio needs
It's code mod no 22dc279/62p prodno fd0100040036177 then other codes rn279fy0036177 t0v972 also
770434425tv972 770434425
Just wandered if someone knows the code cheers
Username: Iwos
Post Number: 938
Jason Kelly
Username: Jk125
TRY CODE .. 4073
Username: Jk125
No good mate using the numbers 1-4 1 being the first number and press it 4 times nothing changes
Username: Iwos
Post Number: 939
Jason Kelly
770434425 TV972
Code Is good mate .. 4073
See link.
http://www.dndservices.co.uk/renault-22dc279-62p.html
Username: A_troll
Need radio code for Volvo C70 (SC-901):
ALE710W1221476
M81221476
Username: Jk125
Ok almedia I have put the code in as it has shown me on you tube pressing number one 4 times number doesn't come up on dash digits then ye can't put anything in for
0 then I have tried to put 7 in using the 3rd button nothing then put the 3 in with the 4th button but nothing happens can you give me any hints cheers
Username: Dekster
POLAND
Post Number: 2091
A_TROLL
sorry we can't help
Main Dealer or a Decoding Service only for this code
contact me: http://koddoradia.pl/
Username: Jk125
No one bother answering during the week
Username: Hogied
Need code for a 2005 Renault Megane radio model #22DC277/62. security digits O981.
Thanks
Username: Iwos
Post Number: 945
hogied
Username: Hogied
try code .. 1001
Username: Ceri93
Hi there,
I'm looking for a radio code for a Renault Clio 1.4 16V Dynamique 3dr 56 plate I haven't got the security code as I don't have the tools to remove the radio to find it ... The battery was taken out so it reset the whole radio system and it is now reading 0000'i have tried different codes but just comes up with an error message hoping someone can help,
Thanks in advance
Ceri
Username: Decode_radio
Post Number: 633
Ceri93
Username: Ceri93
serial numbere from radio please without it we can't help
contakt me http://forum.kody-radio.pl
Username: Jk125
Does no one have an answer why my radio code that Almedia sent 4073 won't go in I am pressing 1 button 4 times 2 button not use then so on and so on
Username: Iwos
Post Number: 960
Jason Kelly
Username: Jk125
The Code number is entered by using the remote steering controls, and not through the buttons on the fascia.
Please note that code entry is only possible when a numbers is flashing in the seperate display.
