New member Username: IlgrazzPost Number: 1 Registered: Feb-15 | Hello I took my Ford Fiesta at the mechanic and the radio code is lost My serial number is M089234 Can you please provide code? Tnx |
Silver Member Username: Decode_radioPost Number: 589 Registered: Jan-14 | GRAZIELLA New member Username: Ilgrazz CODE 3760 contakt me http://forum.kody-radio.pl |
New member Username: IlgrazzPost Number: 2 Registered: Feb-15 | Thank you very much. Code is correct. |
New member Username: Ang12345Post Number: 2 Registered: Mar-15 | Hello can anyone help me with a 6000 ford stereo code serial no v320999 thanks |
Gold Member Username: DeksterPOLAND Post Number: 2099 Registered: Sep-12 | Daz Ford V Serial codes are not usually available for free from anywhere on the Internet (unless you can blag it for free from Ford) as they are not calculated using software but require access to the Ford factory database( via a Ford Dealer)...which is not commercially available as software. Otherwise try your Ford Dealer or a Radio Decoding Service Duplicate post....Already answered contact me: http://koddoradia.pl/ |
New member Username: Bex71Newquay, Cornwall United Kingdom Post Number: 1 Registered: Mar-15 | Hi, hopefully someone can help me. I have bought a ford fiesta finesse and I need a code for the radio but I do not have a serial number. When I press 1 and a 6 it displays the number 50 7000 12 but this is too long to put into a code generator. When I press 2 and 6 nothing happens. Thanks |
Silver Member Username: Decode_radioPost Number: 638 Registered: Jan-14 | Bex71 New member Username: Bex71 add serial numbers from radio contakt me http://forum.kody-radio.pl |
