Silver Member Username: Titanum123Post Number: 961 Registered: Oct-13 | lightless New member Username: Flightless try code 6323 |
New member Username: MeisterPost Number: 1 Registered: Feb-15 | Hi, I need a radio code for this BP0751A2250447 7640751010 THX |
Silver Member Username: IwosPost Number: 762 Registered: Jul-14 | Meister New member Username: Meister Hello, TRY CODE .. 0793 |
New member Username: Djakon999Post Number: 1 Registered: Feb-15 | Hi, I need code for radio: BP237534138884 7642375316 |
New member Username: Djakon999Post Number: 2 Registered: Feb-15 | Sorry, double post |
New member Username: OshboshPost Number: 3 Registered: Jan-15 | Hi , sorry to ask again, many thanks, Oshbosh |
Silver Member Username: IwosPost Number: 766 Registered: Jul-14 | Oshbosh New member Username: Oshbosh Hello, BP 377 656 958 311 7 643 776 510 (6146) keycard. This stereo uses a coded Keycard to activate it, a bit like a credit card with a smartchip on it. Duplicate cards can be reprogrammed from the Master Keycard by using the menu on the stereo under the LEARN KC section take alook here please http://www.dndservices.co.uk/paris-rcm-104.html |
New member Username: MeisterPost Number: 2 Registered: Feb-15 | THX |
New member Username: Ciski18Post Number: 1 Registered: Feb-15 | Hi! I need a code for my Fiat 199 MP3 SB05 Small 2 Graphite. BP - Nr 7648543316 Fiat - Nr 7354813000 Blaupunkt Gmbh 815BP854391265514 THX so Much! |
Silver Member Username: IwosPost Number: 767 Registered: Jul-14 | Ciski18 New member Username: Ciski18 Hello, TRY CODE .. 1511 |
New member Username: NagriJeddahSaudi Arabia Post Number: 2 Registered: Feb-15 | Hi, Dear Fellow, I need the code for my Blaupunkt redio of my caprice, 7642240520 BP224055816717 Also let you know that my redio let me allows to enter digits upto 6, so the 4 digit code should be in between 1 to 6 . |
Silver Member Username: Decode_radioPost Number: 530 Registered: Jan-14 | Nagri New member Username: Nagri CODE 2312 or 6756 contakt me http://forum.kody-radio.pl |
New member Username: NagriPost Number: 3 Registered: Feb-15 | Dear The above code did not work. Pls recheck. |
New member Username: NagriPost Number: 4 Registered: Feb-15 | Dear as I informed above that I can not enter the digit above the number 6 in this redio. Is there any thing else. I would realy appreciate your help. Thanks and Best Regards. |
New member Username: Fiat10Post Number: 1 Registered: Feb-15 | hi every body i lost my code fiat punto LOW BP9372X0785533 7649372316 |
Silver Member Username: IwosPost Number: 768 Registered: Jul-14 | fiat New member Username: Fiat10 Hello, TRY CODE .. 5431 |
New member Username: Fiat10Post Number: 2 Registered: Feb-15 | you are the best thank you |
New member Username: Fiat10Post Number: 3 Registered: Feb-15 | he worked |
New member Username: JantjedubPost Number: 1 Registered: Feb-15 | Hello, I bought a radio on eBay without a code. I Searched the net and found a site werd i could retrieve the code. I installed the radio and the code is working but now i don't have the fader function and my rear speakers are not working. what's wrong mayday maydayl |
New member Username: Djakon999Post Number: 3 Registered: Feb-15 | Hi, I need code for radio: BP237534138884 7642375316 |
Silver Member Username: IwosPost Number: 770 Registered: Jul-14 | djakon999 New member Username: Djakon999 Hello, TRY CODE .. 3664 |
New member Username: Punto_2002Post Number: 1 Registered: Feb-15 | Hi, I need code for blaupunkt radio cassette for Fiat punto BP937227221853 7 649 372 316 e1 021426 Thanks in advance |
Silver Member Username: IwosPost Number: 771 Registered: Jul-14 | puntic New member Username: Punto_2002 Hello, TRY CODE .. 6421 |
New member Username: OshboshPost Number: 4 Registered: Jan-15 | Hi, thanks very much for the code, does anyone know how to enter it, the link given doesn't describe it and actually says not to ask, have scoured the net and found instructions for every blaupunkt except this one, help! :-) thanks so much! |
New member Username: ZikretaPost Number: 1 Registered: Feb-15 | Hi,I need a code for my fiat punto BP. radio. BP - nr. 7 649 372 316 Prod.Nr. Fiat 735 272 569 Thanks! |
Bronze Member Username: BeigmarPost Number: 12 Registered: Aug-11 | Friend I need the code of a blaupunkt fiat 310 mp3 medium used in fiat punto 2008, the code that has in it are these. 815bp739276455731 7647392316. appreciate the help. |
Silver Member Username: Decode_radioPost Number: 537 Registered: Jan-14 | beigmar Bronze Member Username: Beigmar CODE 6353 contakt me http://forum.kody-radio.pl |
New member Username: Realwan44Post Number: 7 Registered: Jul-13 | Hello, needs a suzuki blaupunkt radio code serial# 31927995 7643063510 9 39101-86G10... thank you |
Silver Member Username: Decode_radioPost Number: 538 Registered: Jan-14 | realwan New member Username: Realwan44 CODE 8510 contakt me http://forum.kody-radio.pl |
New member Username: Frostproof, FL United States Post Number: 1 Registered: Feb-15 | Hey, thanks for your help. Fiat Panda BP-Nr: 7643383316 Fiat: 735371187 815 BP338341138007 Fiat 169cc 7643383316 |
Silver Member Username: IwosPost Number: 779 Registered: Jul-14 | frostproof New member Username: Frostproof Hey, TRY CODE .. 2423 |
New member Username: ZikretaPost Number: 2 Registered: Feb-15 | Hey! no code for me? BP - nr. 7 649 372 316 Prod.Nr. Fiat 735 272 569 |
Silver Member Username: IwosPost Number: 781 Registered: Jul-14 | Zikreta79 New member Username: Zikreta Hey, Serial BP9372 12345678 |
New member Username: ZikretaPost Number: 3 Registered: Feb-15 | ok sorry, serial is BP9372X0775563 bp-nr. 769 372 316 prod.nr.735 272 569 thanks! |
Silver Member Username: IwosPost Number: 784 Registered: Jul-14 | Zikreta79 New member Username: Zikreta Hello, Your Code .. 3464 |
New member Username: ZikretaPost Number: 4 Registered: Feb-15 | It works! Thank you! |
New member Username: OshboshPost Number: 5 Registered: Jan-15 | hi,, got the code to work, was fiddling with the buttons and 0000 appeared, then used the code and its working! thanks a million for your help! |
New member Username: MixonPost Number: 1 Registered: Feb-15 | Hello, can I have code for: Serial: BP9372Y3620265 Part No: 7649372316 Thank you in advance!!! |
Silver Member Username: Titanum123Post Number: 972 Registered: Oct-13 | mixon New member Username: Mixon try code 3631 |
New member Username: SushilidduPost Number: 1 Registered: Feb-15 | serial:9440282764841023801377 Part : 7354859440 sw version: 03 Prod date:3410 F199IN 16450004626019 Please tell code.. Please |
Bronze Member Username: BeigmarPost Number: 13 Registered: Aug-11 | Thank you friend . |
New member Username: Tudor_lPost Number: 1 Registered: Feb-15 | I need your help with the code for the nav Blaupunkt on my 2002 Fiat Punto details: 881 BP143017747189 Fiat RNS3 7 612 001 433 e1 021427 thanks in advance! |
Silver Member Username: IwosPost Number: 808 Registered: Jul-14 | Tudor_L New member Username: Tudor_l Try Code .. 5298 |
New member Username: PedrolapitaPost Number: 1 Registered: Feb-15 | I really need your help, I lost my code maybe you can help. 7 649 372 316 BP9372X0837261 thank you very much |
New member Username: SushilidduPost Number: 2 Registered: Feb-15 | Posted on Monday, February 09, 2015 - 08:32 GMT serial:9440282764841023801377 Part : 7354859440 sw version: 03 Prod date:3410 F199IN 16450004626019 Please tell code.. Please ALMEIDA you didn,t reply my post. Please I need it urgent. Or please suggest me something else. |
Silver Member Username: Decode_radioPost Number: 546 Registered: Jan-14 | speedmax New member Username: Sushiliddu Post the 14 character Serial Number beginning BPxxxxxxxxxxxx found stamped in the metal casing contakt me http://forum.kody-radio.pl |
Silver Member Username: IwosPost Number: 809 Registered: Jul-14 | Pedro New member Username: Pedrolapita try code .. 2534 |
New member Username: SalturiPost Number: 1 Registered: Feb-15 | Hello, can I have code for: Serial: BP739388814615 Part No: 7 647 393 316 Thank you |
New member Username: PedrolapitaPost Number: 2 Registered: Feb-15 | Almeida, thank you very much for your quick and perfect help! |
New member Username: Tudor_lPost Number: 2 Registered: Feb-15 | entered the code and worked like a charm. many thanks Almeida |
Silver Member Username: Decode_radioPost Number: 551 Registered: Jan-14 | Salturi New member Username: Salturi CODE 2121 or 6969 contakt me http://forum.kody-radio.pl |
New member Username: SalturiPost Number: 2 Registered: Feb-15 | Excellent. It worked Thank you very much |
New member Username: AntoniobanderasPost Number: 3 Registered: Feb-15 | I've blocked my car radio.. blaupunkt in a fiat punto SERIE NR. BP937213844088 BP nr.7649372316.. prod.nr.fiat 735272569 |
Silver Member Username: Decode_radioPost Number: 561 Registered: Jan-14 | antoniobanderas New member Username: Antoniobanderas Duplicate post, already answered contakt me http://forum.kody-radio.pl |
New member Username: Puntsikka2000Post Number: 1 Registered: Feb-15 | Hello Hello, can I have code for: WAIT WAIT WAIT Serial: BP9372X0834162 BP-Nr 7 649 372 316 Prod. Nr. Fiat 735 272 569 Thank you |
Silver Member Username: IwosPost Number: 824 Registered: Jul-14 | Raimo New member Username: Puntsikka2000 Hello, TRY CODE .. 4245 |
New member Username: Puntsikka2000Post Number: 2 Registered: Feb-15 | Thanks Very Many ALMEIDA, It Works! |
New member Username: Rosanne144Post Number: 1 Registered: Feb-15 | Hi there, Looking for the code for blaupunkt radio in my fiat panda 2004 BP338533749549 7643385316 Thanks a lot!! Rosanne |
Silver Member Username: IwosPost Number: 826 Registered: Jul-14 | Rosanne New member Username: Rosanne144 Hello, TRY CODE .. 1161 |
New member Username: Rosanne144Post Number: 2 Registered: Feb-15 | It works!! Super thanks! You made my day |
New member Username: FirexPost Number: 1 Registered: Feb-15 | Hi, I recently disconnected my battery from my Fiat Punto 2001 and now I need my radiocode, but I didn't write this down? Can someone help me? BP937215341499 7 649 372 316 Prod. Nr. Fiat: 735 289 639 Thanks very much! |
Silver Member Username: IwosPost Number: 841 Registered: Jul-14 | FireX New member Username: Firex Hello, TRY CODE .. 6315 |
New member Username: MeetsaniGlasgow, Lancashire United Kingdom Post Number: 1 Registered: Feb-15 | Hi. I recently bought my fia And the radio is on code. If someone can help he please. Serial no. BP937237525844 7649372316 Many thanks |
Silver Member Username: IwosPost Number: 846 Registered: Jul-14 | arsalan New member Username: Meetsani Hello, TRY CODE .. 2533 |
New member Username: MeetsaniGlasgow, Lancashire United Kingdom Post Number: 2 Registered: Feb-15 | Thank u so much |
New member Username: AtomnyusziPost Number: 1 Registered: Feb-15 | Hi! A friend of mine has a Fiat Punto and he needs a code for the radio. Serial + part number: http://prntscr.com/69p24u Thank you! G. |
New member Username: GauronixPost Number: 1 Registered: Feb-15 | Hi, I need a code for my Fiat Punto Radio! Blaupunkt low BP937227208361 7 649 372 316 thx!! |
Gold Member Username: DeksterPOLAND Post Number: 2058 Registered: Sep-12 | Ronin CODE 1413 contact me: http://koddoradia.pl/ |
Gold Member Username: DeksterPOLAND Post Number: 2062 Registered: Sep-12 | G. CODE 1413 contact me: http://koddoradia.pl/ |
New member Username: Lga90296Post Number: 1 Registered: Feb-15 | Hiya how do you get the serial number please xx |
Silver Member Username: Decode_radioPost Number: 598 Registered: Jan-14 | Laura New member Username: Lga90296 remove radio from car serial numbers are on metal case contakt me http://forum.kody-radio.pl |
New member Username: Fraser5002Post Number: 1 Registered: Feb-15 | Hi. Great job. Wonder if you could help me also? Fiat 05 plate Blaupunkt radio BP338341142140 7643383316 |
Silver Member Username: Decode_radioPost Number: 599 Registered: Jan-14 | fraser5002 New member Username: Fraser5002 CODE 3566 contakt me http://forum.kody-radio.pl |
New member Username: Donny121Post Number: 1 Registered: Mar-15 | Maybe someone could help me please FIAT PUNTO Bp serial: 7 642 374 316 FIAT serial:735 337 935 Another code: A151 Thanks for your assistance. |
New member Username: MartyxCeske Budejovice, Tschechien Post Number: 1 Registered: Mar-15 | Hello, can someone tell me code for my Blaupunkt BP854391261191, fiat ser. 7648543316 Thank You! |
Silver Member Username: IwosPost Number: 886 Registered: Jul-14 | donny Post the 14 character Serial Number beginning BP2374xxxxxxxx found stamped in the metal casing |
Silver Member Username: IwosPost Number: 887 Registered: Jul-14 | Martyx New member Username: Martyx Hello, TRY CODE .. 4236 |
New member Username: Oxide_99Post Number: 1 Registered: Mar-15 | Hi, I need a code for my Fiat Punto Radio are you able to assist? 2000 model car Blaupunkt-werke gmbh Fiat Punto LOW BP9372Y1168597 7 649 372 316 Thanks in advance |
Gold Member Username: Titanum123Post Number: 1015 Registered: Oct-13 | oxide New member Username: Oxide_99 try code 4541 |
New member Username: Oxide_99Post Number: 2 Registered: Mar-15 | Thanks will try later and get back to you |
New member Username: AldatorPost Number: 1 Registered: Mar-15 | Hello, can I have code for: PUNTO / FIAT 199 MP3 SB05 BP854391261191 7 648 543 316 Thank you. |
Gold Member Username: Titanum123Post Number: 1019 Registered: Oct-13 | Aldator New member Username: Aldator try code 4236 |
New member Username: AldatorPost Number: 2 Registered: Mar-15 | Thank you very much |
New member Username: Oxide_99Post Number: 3 Registered: Mar-15 | No luck with code with 4541 Any other suggestions? |
Gold Member Username: DeksterPOLAND Post Number: 2071 Registered: Sep-12 | oxide Try CODE 6361 contact me: http://koddoradia.pl/ |
New member Username: NsirimenPost Number: 2 Registered: Mar-15 | Hello i need a code for my grande punto radio blaupunkt can you help me please?! BP 632862805347 BP-NR 7 646 328 316 Fiat-NR 735 429 579 0 thanks in advance |
Silver Member Username: Decode_radioPost Number: 617 Registered: Jan-14 | imen New member Username: Nsirimen CODE 4214 contakt me http://forum.kody-radio.pl |
New member Username: NsirimenPost Number: 3 Registered: Mar-15 | Thanks |
New member Username: Sam2887Post Number: 1 Registered: Mar-15 | Hi. I need help with a code for my fiat panda 04 cassette player serial num Bp338330978699. .. any help would be appreciated regards samantha |
Gold Member Username: Titanum123Post Number: 1030 Registered: Oct-13 | samantha New member Username: Sam2887 try code 4216 |
New member Username: Sam2887Post Number: 2 Registered: Mar-15 | It won'tlet me put a code in as it's saying wait??? How can I get passed this problem so I can try the code regards samantha |
New member Username: Sam2887Post Number: 3 Registered: Mar-15 | It won'tlet me put a code in as it's saying wait??? How can I get passed this problem so I can try the code regards samantha |
New member Username: Jb88Lisboa, PORTUGAL CON... Portugal Post Number: 1 Registered: Mar-15 | Hi guys My cousin has a fiat 500 cant find the code for the radio :s this is the information present on the side of the radio. thanks in advance |
New member Username: Jb88Lisboa, PORTUGAL CON... Portugal Post Number: 2 Registered: Mar-15 | Hi again guys I dont know if you need this too but... thanks in advance |
Gold Member Username: DeksterPOLAND Post Number: 2074 Registered: Sep-12 | Branco CODE 3221 contact me: http://koddoradia.pl/ |
New member Username: KwaroksPost Number: 1 Registered: Mar-15 | Can somebody help me. It's the code for my 2001 Fiat Punto |
Gold Member Username: DeksterPOLAND Post Number: 2076 Registered: Sep-12 | Raoul CODE 1623 contact me: http://koddoradia.pl/ |
New member Username: Jb88Lisboa, PORTUGAL CON... Portugal Post Number: 3 Registered: Mar-15 | it worked!! tank you very much Dekster |
New member Username: Jb88Lisboa, PORTUGAL CON... Portugal Post Number: 4 Registered: Mar-15 | it worked!! tank you very much Dekster |
New member Username: AkilijusBelgrade Post Number: 1 Registered: Mar-15 | Hello....I need radio code for Fiat Panda 169cc BP338974297383 7643389316 Thx.... |
